Will not start when turning ignition alone
I know that there's probably many different things that could cause it, but I've been having this problem of the car not starting when I turn the key alone. I have to press the gas pedal a little and turn the key at the same time for it to get moving. Any ideas as to where I should start looking?
TIA,
Matt
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-03-2005, 10:11 PM
Throttle position switch?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-04-2005, 07:23 AM
SoCal Driver's Avatar
Second that; throttle switch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-04-2005, 10:41 AM
