Send a message via AIM to drfatz
Short Shift Help!
Ok so the car is finished after 50 hours of a clutch job....except for the linkage. I purchased a weltmeister short shift kit (same as shown here Short Shift so mine has a long shaft with a ball joint on it and a metal plate at the bottom...also included is an aluminum block with three holes in it...two small and one large. The instructions that came with it are complete crap. It says to disconnect trans linkage but it says nothing about the shift itself. I have NO idea how to put this in and right now the car is just minutes away from driving after 4 weeks execpt for this *(&(*&^ shifter! ANY help would be very much apprecaited.
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 07-17-2005, 09:13 AM
So an update...I installed the old shifter just to get the car on the road and I called Weltmeister (now Performance Products) who proceeded to tell me that they could offer no assistance installing this part, the best they could do was let me return it. How do they expect people to install their parts when there are basically no instructions with it? He told me that they are supposed to be installed by a "Porsche garage" and I said that I just rebuild the engine and redid the clutch/trans and I STILL can't figure this silly thing out! I'm dying here..........
-GD
1985.5 944 NA
Old 07-18-2005, 09:19 AM
NAstyDAsh's Avatar
I think the reason you're not getting any responses is.....
Like me, lots of us have installed the short shift linkage, but I'm not sure if anyone has installed that other piece you are referring to.
I saw that block with the three holes on eBay advertised as a short shift eBay short shift , but I have no idea where it goes or what it does.
Maybe you got a deal and got two short shift kits (the linkage and the block)?
I think the linkage alone is a vast improvement over the stock. Why not just install the linkage and see what you think. It installs just like when you put the old one back on
Early 85 944 NA
5 Speed
Mostly Stock
Old 07-18-2005, 07:07 PM
Does this install at the tranny, and not at the shifter?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 07-18-2005, 08:34 PM
SoCal Driver's Avatar
Should do a search. Think it installs at the trans.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-18-2005, 09:20 PM
I appreciate the input but I figured it out. You remove the stock linkage AT THE TRANS. I found a Paragon tech session that explains how to install my exact kit... http://www.tech-session.com/kb/index.php?page=index_v2&id=42&c=4. I hopefully will be putting it on tonight. If I had known that it was for the trans I would have installed it while it was out of the car however, nothing came with the kit :-/
1985.5 944 NA
Old 07-19-2005, 05:55 AM
I took so long to respond because I was trying to figure how to fit it at the shifter. Sure looks like it would be easier to install with the tranny out, but I would think you have room with the transmission in the car. Sure would like to see your car once its finished, you've got some interesting mods.
Old 07-19-2005, 09:04 AM
