TNT25169's Avatar
Send a message via AIM to TNT25169
A/C Delete Kit Help
I just purchased an A/C delete kit because the compressor was completely broke and A/C is overrated anyways. I am just not really sure what to do with this bracket now. Has anyone installed this kit onto their car? I have the bracket, the shroud and a new belt. From what I've read, I'm supposed to remove the alternator and I'm guessing lower it to where the compressor was but I'm not really sure. Any advice is welcome. Thanks guys.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 08-02-2005, 07:44 PM
aribop's Avatar
Remove the alternator.
Remove the compressor.
Take the old bracket off - 4 bolts.
Install the new bracket.
Install alternator on the bracket - goes where the compressor used to sit.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 08-02-2005, 09:24 PM
TNT25169's Avatar
thank you sir
www.apartabove.com
Old 08-02-2005, 10:07 PM
disgusted
THE manning's Avatar
Re: A/C Delete Kit Help
Originally posted by TNT25169
...A/C is overrated anyways.
HELL YEAH!!! I'm with you on that one, especially living up here in NE Ohio. Now when I lived in Savannah, GA on the other hand...
Michael Manning
95 Independent Fabrication Deluxe
You are not what you own!
Old 08-03-2005, 01:07 PM
tifosiman's Avatar
Yeah, and FWIW, everyone that tells you that your Alternator will self-destruct without the black shroud (which will no longer fit when you re-locate the alternator lower) are exaggerating. I have not had one for a long time since I deleted the A/C and have had no issues.
Knocks on wood.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 08-03-2005, 01:10 PM
fast924S's Avatar
Send a message via AIM to fast924S
Yea I just picked up a used AC delet kit from SERGE over at rennlist, cant wait to install it
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-03-2005, 01:58 PM
disgusted
Knocks on wood.
Heck Tifo, the 924S did not even come with a shroud from the factory, period. Neither did the early 944s. I have to agree that is really isn't to necessary on a non-turbo 944.
But to your point about the shroud not fitting, there is actually a specific shroud for the AC delete cars. I have one of each type.
Michael Manning
Old 08-03-2005, 08:56 PM
tifosiman's Avatar
Yeah, I got the part# after my swap but then said the heck with it and decided not to worry about it.
Sidney Goff
Old 08-04-2005, 04:21 AM
Mike C5.'s Avatar
I probably shouldn't say it but my early 944 is still on the original (non-shrouded) alternator at 212K miles....
Early 85 944
Old 08-05-2005, 06:11 PM
Fernie_Wan_Kenobi
fmartinez1897's Avatar
Anyone have detailed instructions as to how to do this?
Old 05-31-2013, 07:07 PM
