A/C Delete Kit Help
I just purchased an A/C delete kit because the compressor was completely broke and A/C is overrated anyways. I am just not really sure what to do with this bracket now. Has anyone installed this kit onto their car? I have the bracket, the shroud and a new belt. From what I've read, I'm supposed to remove the alternator and I'm guessing lower it to where the compressor was but I'm not really sure. Any advice is welcome. Thanks guys.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Remove the alternator.
Remove the compressor. Take the old bracket off - 4 bolts. Install the new bracket. Install alternator on the bracket - goes where the compressor used to sit.
'95 993 Monster in the making '89 S2/Turbo aluminum grill monster: terrorizing another state |
thank you sir
disgusted
Re: A/C Delete Kit Help
Michael Manning 95 Independent Fabrication Deluxe You are not what you own! |
Yeah, and FWIW, everyone that tells you that your Alternator will self-destruct without the black shroud (which will no longer fit when you re-locate the alternator lower) are exaggerating. I have not had one for a long time since I deleted the A/C and have had no issues.
Knocks on wood.
1985.5 944 Club Sport My P-caronline Profile "A good time to keep your mouth shut is when you're in deep water. "-- Sidney Goff |
Yea I just picked up a used AC delet kit from SERGE over at rennlist, cant wait to install it
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
disgusted
But to your point about the shroud not fitting, there is actually a specific shroud for the AC delete cars. I have one of each type.
I probably shouldn't say it but my early 944 is still on the original (non-shrouded) alternator at 212K miles....
Early 85 944 |
Fernie_Wan_Kenobi
Anyone have detailed instructions as to how to do this?
Thread Tools | |
Rate This Thread | |
