Question A/C Compressor Clutch Replace
Hello,
First off - I'm new here - found what I considered to be a great deal on a '89 944 (have yet to pick it up) - 2.7L - however it has one issue:
A/C belt is making noise, the ! light is on the dashboard, and the altrenator isn't fully charging - previous owner says odds are it's the compressor clutch, and he even has the part.
Few questions:
Is there anything different to look out for, or just the usual process of: undo the nut for the A/C pulley, then slide out the spacers and the clutch, reassemble with a new one?
What size nut is holding the pulley/clutch on the compressor spindle?
Is this best approached from the topside or underneath the car?
Thanks in advance - hopefully I'll be able to contribute some of knowledge in the future.
Old 09-12-2005, 06:54 PM
AFJuvat's Avatar
Welcome to the BBS
Make sure the belt is tight enough before you start tearing things apart - the alternator\ac belt is supposed to be very tight - 1 - 2mm deflection at the most.
Also make sure that the alternator is good - you can have it rebuilt for about $100 or so.
it is easiest to do this with the compressor out of the car, failing that, from under the car. You may need a impact ratchet to remove the nut (12mm or 13mm).
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-12-2005, 08:46 PM
Thanks for the tips.
Old 09-13-2005, 04:08 AM
Burn the fire.
Brando's Avatar
If you do end up going with a new compressor, check what's out there... My dad's replacing his old SC compressor with a newer rotory compressor... Although, I don't know much of the specs between different compressors...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-13-2005, 11:44 AM
