winter-hater club member
nynor's Avatar
how do i get this thing on stands?
i need to get my car on stands in order to check out wastegate lines, etc. how do i get it there, and wear can i put the stands?
the tools i have:
1. original porsche jack
2. two wheel ramps, but they are too steep to clear the front valance
3. two jack stands
4. a hydraulic bottle type jack
"COOL PRIUS!" - Nobody Ever
Old 10-06-2005, 11:28 AM
Parrothead member
VINMAN's Avatar
I made ramp extensions out of stacked 2x8s to get the clearance on the front valance. The jacks stands I put just in front of the front doors
Vinny
Old 10-06-2005, 11:42 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Uhmmmmm buy a new jack
IN a rush...
- I stick a piece of wood on the jack slide it right in the middle of the crossmember.........raise it up and place both jacks on the rails under the car....... they are spaced out approximately 16 inches from either side.
Don't place jacks on the donut holes of the car. The floor will break.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-06-2005, 11:57 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
If you're going to use a piece of wood, put the wood on the jack, never under it.
I cut some very small, maybe 2"x4"x1" pieces of wood that fit into the side jack points under the doors. A proper jack pad would work better, but I didn't want to put the metal directly against my jack and I just wanted to get it in the air.
When you get it up on stands, I read a suggestion not-too-long-ago on this board where the guy puts the wheels under the car also, just in case something lets go.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 10-06-2005, 12:23 PM
Eldorado's Avatar
how about jacking the car up onto the ramps?
that's what i did for the last job.... safer than stands..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-06-2005, 01:16 PM
nynor's Avatar
***how about jacking the car up onto the ramps?
that's what i did for the last job.... safer than stands..***
ok. that is an idea. will the porsche jack get it high enough?
i have also put the wheels under the car... i am VERY paranoid. just like i everyone else probably, i knew someone that died because their car fell on them.
Old 10-06-2005, 01:26 PM
ae1969's Avatar
Probably not...
The front wheels will sag...
Old 10-06-2005, 01:33 PM
Eldorado's Avatar
how tall are the ramps?
now extend the jack as far as it will go.... does it lift it high enough?
if not, borrow a jack....
or do what was suggested and build pre-ramps with pieces of wood...
Kyle
Old 10-06-2005, 01:59 PM
nynor's Avatar
good plan. i'll post pictures when i get around to this.
Old 10-06-2005, 02:08 PM
2x8's are enough to get me onto ramps, and there is no reason you can't do wastegate and exhaust work with the car on ramps.
I also have to drive onto 2x8's in order to get my jack under the car enough to put it on stands.
-Ian
Stock 1988 951, TT aero wipers
Old 10-06-2005, 02:23 PM
Non Compos Mentis
[i]Don't place jacks on the donut holes of the car. The floor will break. [/B]
Really? I've used the donuts for a long time.
Old 10-06-2005, 02:53 PM
Sears runs a sale from time to time on a floor jack and 2 jack stands (less than $30 I think). The jack will fit under my 944 with a piece of 2x4 for a jack pad, and you really should have a jack you can use conveniently and 4 jack stands if you're going to do much work on your 944.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-06-2005, 05:39 PM
I know this isn't the way your supposed to do it but I jack up one side at a time. Use the jack point on the side of the car, put a stand behind the control arm on the cross member, let it down. Then as fast as i can, get to the other side and get it up and on a stand. Then put the jack in the middle, since the stands aren't usually on all fours, and position every thing just how I want it. It would be a lot easier if the floor jack could fit under the front of the car.
Old 10-06-2005, 10:49 PM
Non Compos Mentis
I jack up one side at a time, but I usually use four stands and have the entire car off the ground.
Four stands using four donuts. Is that bad?
Old 10-07-2005, 10:19 AM
ae1969's Avatar
Yup
There is next to NO supporting metal behind the two in the front..
I had to weld the one side. Previous owner had collapsed one on the TUrbo. The NA had the drivers side that was ready to tear as well.
THey hold but for how long is the question....
Old 10-07-2005, 12:32 PM
