Send a message via AIM to hpaulb
Red face left click
I hear a click every right turn? It just went through a safety check and they didn't say anything was wrong with the suspension? How is the easiest way to check what's loose/causing it?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 10-06-2005, 10:00 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Usually a click while turning points toward a wheel bearing, but it really could be a number of things... hell, a loose bolt or lug nut, or even a loose center cap could cause strange sounds. Is it coming from the front? Rear could also point toward CVs...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 10-06-2005, 10:02 AM
Mein Gott!
Panzer909's Avatar
I'm thinking CVs too. Is it a single click for every turn, or is it more of a TINK TINK TINK throughout the turn?
Are my sound effects accurate?
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-06-2005, 01:11 PM
sca037's Avatar
If it is a single 'click' when first turning, another possibility is that it's the door.
My 944 does this sometimes, but I've never investigated as to why it does it........
Brian
'85.5 944 (sold and will be missed)
Sport seats, LSD, sways, 7 & 8" Fuchs
Old 10-07-2005, 05:09 AM
It's one click ever right turn. Sounds like its in the left front area but were?
98 BMW 740i
Old 10-07-2005, 06:38 AM
If it does come from the door, it's probably the crossbar.
To figure this out, I took off the door panel and simulated the conditions where it clicked. All I did was quickly jerk the wheel and correct, on a rural road w/o traffic, of course. With my other hand, I felt in the door. You can feel the crossbar flex.
To tighten this, it requires a 12-point socket. I have a set of 4...6,8,10,12mm...none of them fit. I ended up nearly stripping one bolt trying to get one socker into it. If it's possible to find an odd cheesehead socket, I guess you could try that. I eventually gave up and let the door click.
Old 10-07-2005, 08:02 AM
vott does ziss do?
ronin's Avatar
sway bar bushing. check under the left front of the car to make sure yours hasn't squeezed out of the clip
Old 10-07-2005, 08:57 AM
