dsalillas's Avatar
Need Some Head Help
Okay,
I've got a 90 S2 that suffered a chain tensioner failure about a year and a half ago. The valves look fine but the mounting boss broke leaving the plug hole intact. I bought a rebuilt head anyway and finally got around to putting it in.
Here's my problem. I have the flywheel at TDC and put the cams in per FSM and Mr. Mitros Pics(thanks BTW) now I can't turn the crank by hand. With the belt off and the cams set the crank turns fine. As soon as I put the belt on I get about a quarter turn and that's it. Could it be the rebuilt head has been in my garage so long that its frozen? I 've been at this for three days now and about to give up. If I can't get it running by tommorrow, off to the shop it goes. Any suggestion before it comes to that would be greatly appreciated.
TIA,
Drew
84 944 (RIP)
85.5 944 (RIP)
88 944S (about to be parted)(traded for S2 Engine)
90 944S2 Cab. (finally running after head surgery)(now with a new engine)
Old 10-09-2005, 12:42 PM
AFJuvat's Avatar
Are you sure that teh cams are timed correctly? Are you sure that the cams are installed properly?
Sounds like something is binding up in the head.
Double check, measure, and verify everything.
AFJ.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-09-2005, 12:53 PM
dsalillas's Avatar
I've pulled them out and checked them four times getting the same results. I know I measured the distance btween the cast lugs correctly.
I'm at a loss.
84 944 (RIP)
85.5 944 (RIP)
Old 10-09-2005, 12:58 PM
dsalillas's Avatar
Well it looks like I'm done with tinkering with it, more like cursing at it, for the day. I won't be able to get it towed until Wed. so I have a couple of days to work at . Any suggestions? Bueller... Bueller...
Thanks,
Drew
84 944 (RIP)
85.5 944 (RIP)
Old 10-09-2005, 06:01 PM
konan's Avatar
Maybe you're a full turn off instead of all lined up.....
Old 10-09-2005, 06:58 PM
konan's Avatar
or is it half turn?
Old 10-09-2005, 06:59 PM
dsalillas's Avatar
I'm pretty sure the crank is at TDC. I checked at the flywheel, #1 is all the way up, and all my pulleys are marked with paint.
84 944 (RIP)
85.5 944 (RIP)
Old 10-09-2005, 09:04 PM
When I measured the distance on the lugs per the factory workshop manual, I thought the picture was from the front of the engine, it is actually from the rear, looking forward--maybe this is your problem.
Just a suggestion........
Jeff
Jeff Laurence, '87 944S
Old 10-09-2005, 10:12 PM
I assume FSM means factory shop manual? Make sure the lobs of the cams look the same relative to the pics in the FSM.
Jeff
Old 10-09-2005, 10:16 PM
dsalillas's Avatar
I checked them and they match exactly. I'm gonna try to turn the crank with just the exhaust cam in to try and narrow done which cam is binding.
84 944 (RIP)
85.5 944 (RIP)
Old 10-09-2005, 10:45 PM
dsalillas's Avatar
Here's an update. I removed the intake cam and just used the exhaust cam by itself and it turn effortlessly. So I narrowed it down to the intake side. How do I troubleshoot this?
84 944 (RIP)
85.5 944 (RIP)
Old 10-10-2005, 10:20 PM
dsalillas's Avatar
Another update. I put the exhaust cam from my old head in and I got the same results. It won't turn either. So I've narrowed it down to the two#4 intake valves since they are the first to open.
Now what?
84 944 (RIP)
85.5 944 (RIP)
Old 10-10-2005, 11:22 PM
dsalillas's Avatar
The #4 intake valves were stuck. I used a 3/4 pvc coupler and compressed the springs. There was a little resistance then a slight pop. They move up and down pretty freely now. I'll have to check the rest of the valves later. I may try to run the cam without the lifters in to see if ts binding, hand turning of course.
84 944 (RIP)
85.5 944 (RIP)
Old 10-11-2005, 12:55 PM
dsalillas's Avatar
Newest update:
I've freed up all the frozen valves, cams are in, timing belt set, and everything put back together.
Now my newest problem which I'm sure many of you had.
It won't start. The starter and crank are turning but I'm either not getting fuel or no spark.
I'm so close, I can't stand it.
What's the simplest ways to check both of those?
84 944 (RIP)
85.5 944 (RIP)
Old 10-12-2005, 12:24 PM
konan's Avatar
If your a turn off,in other words you would still be able to not bend valves but your firing will hit when the piston is not under compression.
Old 10-12-2005, 04:45 PM
Dme relay?
Old 10-12-2005, 06:47 PM
Compression?
Old 10-12-2005, 07:05 PM
dsalillas's Avatar
Dme is ok, the tach jumps when I try to start it. I haven't checked compression yet. I'm thinking its a fuel problem cause I don't smell any fuel with all the cranking I've done.
84 944 (RIP)
85.5 944 (RIP)
Old 10-12-2005, 09:22 PM
