Squeak squeak from power steering area
Yesterday while idling in the waiting line at PCA AutoX, I noticed the car was squeaking from the front end. Got down there to listen and look, and it appears to be coming from the power steering. Belt, or pulley, I don't know.
Don't know when the belt was last changed. But, pushing on the belt when the car is off you can hear it creak a bit. Belt is not squealing like a stuck pig. Whatever it is, it's just a "squeaksqueak" Most likey just an old belt in need of replacement? ![]() Or could the pump be on it's way out? Any way to test the pump?
disasemble ( pull belts ) and clean pulleys ...
Replace and PROPERLY tension them ( till no squeek )Me: squeek... add PS fluid
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat |
