Dash Clock Trim
I have everything apart to replace my dash digital clock except one piece. I have a 1986 944. On the far right of the dash trim strip I need to pull the air vent slide control knob through the horizontal vent fins. Is there a way to remove the knob or will the fins flex enough to allow me to gently force it through. I don't want to force it and end up with more broken pieces. Would appreciate someone's help.
Stephen Fraser Poland Spring, ME 1986 Guards Red 944NA |
The fins will flex enough, Just slide the knob to the middle first and BE CAREFUL.
Jeff 78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
If I recall right, you don't have to do any of that. Theres a screw on the side of the dash when you open the door... it stumped me until I almost broke the trim piece.
Custom User Title
I changed my trim just before it went into storage. It should come out with very minimal effort. I dont know that its possible to remove the vent control knob just be careful
I remember the same as Izzy, you shouldn't be removing any of that to remove that trim piece. There is one screw in the middle and one next to the door. It's been a while, but at least that is how I remember.
Tom
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
True, it's only a few screws that hold it on but you do have to squeeze it past the slider knob to pull it off.
Custom User Title
yes, be carefull
