To rebuild, or not to rebuild: Advice needed.
Ok guys this winter im taking apart an engine out of an 87 that i had with 120k miles. Now im going to put it into another car where it will probably be in service for about a year and a half to 2 years. The question is, im doing all the gaskets for the engine, should I do anythign else while im in there. I know i need to do the belts and should probably do the water pump as the motor as been sitting for 2 years, but is there anything else i should do? While im in there should i take the extra little bit of time and do the piston rings? Keep in mind the engine will be used for 2 years, and will be replaced after that. Any advice you can give me is great. Thanks
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
A compresion test will tell you. I've done a freshen up a few times. Just hone and stock rings. It can cause unexpexted problems and Id wished I'd left it alone.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
