Torque Values Needed
I need the correct torque values for the following:
1. Main bearing studs 2. Remaining bolts on crank girdle 3. Rod Bolts Thank You for the help Pete |
What yr and model do you have?
'84 944, '05 GTO |
Sorry, that would probably help.....
1987 944 N/A Thanks Pete |
Nobody has ever changed the bearings and used a torque wrench to reassemble these things?
Anybody got a good guess? JK..... |
connecting Rod nuts. Smooth nut type 46 lbs.
Ribbed nut type 59lbs. What size are the Crank nuts, (Crank lower to upper section) 12mm 15, 29,then 55 lbs or 10mm 15, then 37 lbs there are also additional 8mm 15 lbs, 6mm 7 lbs. I suggest you doulbe check the above from another source to confirm that the above is what you are after. As I am English your terms are slightly different, so doulble check !! |
Thread Tools | |
Rate This Thread | |
