Question about difference between engine
I think I may already know the answer to my question but I still have to ask to make sure.
Is there a difference between a 83 and 86 944 motor? If so whats the difference? Thanks in advance.
Craig - 86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties Past: 89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car |
83 has forged pistons and a different DME. They'll swap in and out with the correct DME.
So what type of piston does the 86 have? Forged vs. cast? wich is better.
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
83 Engine:
Bottom opening for the oil filler/breather is smaller -- the same size as the top. Cam has less duration on the exhaust. Gauge temp sender does not go through into the water jacket. -------------------------------- Do you need an engine?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Pistons are much stronger than the later ones. The rods are forged/sintered.
Kinda just to have a backup on hand that was fairly cheap. Hell, for that matter I'm still looking for a extra head to have laying around. My car runs fine, but its my dailydriver and I tend to drive her hard. Especially in the hills and canyons, tend to take road trip just for fun on my days off.
Craig - 86' 944 N/A Black <-----Daily driver under going a fresh motor install to resume daily driver duties Past: 89' 944 S2 Guards Red Now in the hands of a Pelican who has been wanting another p-car Last edited by McFly944; 12-29-2005 at 10:51 PM.. |
If you buy it get the oil filler/breather with it. You will have to drill and tap a hole for the gauge temp sender.
Everything else will swap over. That is you don't use the early fuel rail, idle control valve, AFS, etc. Use those in the 86. You will want to use the 86's oil pressure relief valve assembly. I found and put an 86 engine in my 83. Had too as the 83 spun a bearing at almost 300,000 miles.
Cool, thanks for the info Hugh. I'm nearing the 300k mark also, and rather be safe then really sorry paying an arm and a leg becasue it has to be done.
