Starting Problem
Now that the car runs there seems to be a recurring problem with how it starts. It seems to crank for a longer than usual time and when it starts the engine pulses/surges for a few seconds before it flattens out adn runs smoothly. I have replaced the fuel pump check valve and this still happens. I then replaced the fuel rail, fuel pressure regulator and fuel damper. I checked the fuel pressure it is good (about 51 psi if I recall) and then checked it again after the engine has been off for about 20 minutes and it was about 43psi. Any ideas what this could
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 03-15-2006, 11:23 AM
SoCal Driver's Avatar
Adjust the speed/reference sensor.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-15-2006, 12:12 PM
I should have added that this is only an intermittent problem. Sometimes it happens and sometimes it doesn't. There is also no one condition when it does happen. It can happen after the car sits, or not, or it can happen after i just shut it off...or not.
Dan
1988 Turbo S (Red)
Old 03-15-2006, 02:07 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
SoCal, would the idle control valve or O2 sensor do that? Dan, was the DME you just put in from the same year, make and model?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-15-2006, 10:19 PM
Back from Beyond
Try swapping out the battery. I know, sounds strange, but low voltages cause lots of confusion amongst the DME sensors and ignition system. I've experienced this first-hand 'cause Canadian winters get kinda harsh, especially on batteries. I've had mornings when the battery's run been down getting the car started and it'll run rough till the alternator puts enough juice back into it. Nope, this isn't a warm-up issue, it's a voltage one. At -30C your temp gauge doesn't move for a long time! I'm not saying your car's caught a chill, just that dying batteries masquerade as other things sometimes.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 03-15-2006, 10:51 PM
Tom - Yes the DME is from the same year, make and model.
Slam - I have had the battery checked a few times and has checked out ok. Actually I have had this problem since i got the car. I had originally thought it was the check valve.
Dan
1988 Turbo S (Red)
Old 03-16-2006, 03:46 AM
Back from Beyond
Voltage regulator? Alternator? Socks?
All others GONE!
Old 03-16-2006, 07:03 AM
the whole charging system was checked at autozone and they said it is all good. Socks?
Dan
1988 Turbo S (Red)
Old 03-16-2006, 10:04 AM
Back from Beyond
Sorry - it's a long-standing joke on this board. Do a search for socks and AFJuvat and you'll see what I mean.
Did you adjust your reference sensors as per Hugh's suggestion? How;s the fuel pressure regulator and damper?
All others GONE!
Old 03-16-2006, 10:32 AM
didn't adjust the reference sensor. If it was the sensor woudln't it be more consistent? HAVe drivent he car for the last 3 days and it hasn't happened.
i just replaced the regulator and damper last week.
Oh, and gave the car a once over and no socks
Dan
1988 Turbo S (Red)
Old 03-18-2006, 06:50 PM
