Scott R's Avatar
How to disable central locking
Have an 87 951 with the central locking system, problem is I go out to the car after its been sitting a while and the locks are up again. I just want to disable the system until have time to tear into it. Is there are relay for this? Or a control brain? I can't find it in my manuals.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-26-2006, 09:15 AM
you can prolly just unplug the switch
Old 03-26-2006, 09:44 AM
Scott R's Avatar
I was thinking about that, however I wondered how much interaction the switch had with the rest of the system.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-26-2006, 09:45 AM
OnTheRun2's Avatar
You could pull the fuse.
(Mae) Red '86 944na- gettting new paint soon.
(Abby) Black '86 944na- new addition to the family.
Old 03-26-2006, 12:40 PM
Scott R's Avatar
Ahh, but which fuse is it? This is another thing I can't locate.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-26-2006, 12:59 PM
Kevin0323's Avatar
Does the late 944 come with a central locking system? If so, mine came DOA.
1985.5 944NA
http://www.kevinswebsite.com/944/
Old 03-26-2006, 01:56 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The central locking mechanism (box) is under the dash clipped to the steering column. Black box.....Uhmmmm 2 inches wide, 3 inches long..... 1 inch deep. Not much to it. You pull that out of the plug.
It is probably locking on you because the microswitches on the door handles are faulty or out of alignment.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-26-2006, 02:15 PM
Burn the fire.
Brando's Avatar
Look under the top for the fusebox. It will have a listing of relays (G##) and Fuses (##). You will see a fuse for Central Locking. If you have the dealership alarm installed, you might want to pull the relay for that first and see if that may be culprit. I think part of the alarm system was that it would engage the central locking to lock the doors when activated.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-26-2006, 02:46 PM
OnTheRun2's Avatar
Fuse #8 controls only the central locking system. Pulling this should disable it for you, untill you can track down the problem.
Good luck
Old 03-26-2006, 02:50 PM
Scott R's Avatar
Thanks guys, that did the trick. Once I get the engine back in my 911 I'll tackle the micro-switches.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-26-2006, 05:50 PM
Kevin0323's Avatar
Does the late 944 have a central locking system?
1985.5 944NA
Old 03-27-2006, 12:43 PM
OnTheRun2's Avatar
It was an option.
Old 03-27-2006, 05:04 PM
