TNT25169's Avatar
Send a message via AIM to TNT25169
Steering boot leaking?
The steering boots on my tie rods are both leaking. Is this normal? It appears to be coming out of a seam in the boot. Everytime I wipe the power steering fluid away, a new droplet appears. Is something leaking behind the boot causing the boot to fill up with power steering fluid? Help!
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 05-01-2006, 08:49 AM
The seals are leaking on the steering rack. Its either time to get a new rack or get a rebuild kit and do it yourself.
86 Red 944(sold)
85.5 Red 944(sold)
Old 05-01-2006, 10:53 AM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
+1 on the leaky steering rack. The bad news is that the rack and tie rods(if you can't reuse them) will set you back a little bit. The good news is that it can all be done with very basic tools, is not difficult to accomplish, and there is an excellent write up on Clark's Garage. Just to reemphasize something that it tells you in the write up, be VERY careful when you are bolting up the new rack. The cross member is aluminum, and it's super easy to cross thread the mounting bolts, ask me how I know. Best of Luck!
Micah
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 05-01-2006, 12:09 PM
TNT25169's Avatar
Thanks for the help guys, I looked over clarks garage while I was waiting for a reply from you guys so I'm familiar with the process. Hopefully I can get this done before my next auto-x.
www.apartabove.com
Old 05-01-2006, 12:21 PM
