V8 Upgrade to a 944
Anyone done a RenegadeHybrid LS1 upgrade to a 944? I am seriously considering it as a fun project, but am extremely leery of the transaxle being able to stand up to 350 lbs of torque. Currently I have a 1985.5 944 NA and was thinking of doing the upgrade and dropping in a turbo transmission with an LSD. Any comments/suggestions would be appreciated.
-G
1985.5 944 NA -Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam, -Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob. Just Finished: Clutch, flywheel and transmission...and TONS more! |
many times.
do a search... there's gold in them hills.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
http://www.560sec.com/bulletinboard -- these guys are all about v8 swaps.
When I do mine, I am going to use the NA tranny I already have, since I have a spare also, but I don't plan on abusing it. A Turbo tranny with a taller NA 5th gear is what most seem to think is the best combo.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
I'm sure you have read this on renegade hybrid's web site, but here it is in case you haven't. "The 944 torque tube and trans-axle remain stock and in their original locations. These components can handle the power output of mild performance motors when used in street driven applications. However, the 944 Turbo trans-axles are stronger and have more favorable gear ratios for the V-8 application. Automatics are not an option with this kit…sorry." They made the kit and they did the testing, I guess you have to believe what they claim. Even if someone on this BBS has done this conversion I think it would be safe to say
renegade hybrid's knows more about their own kits than anyone here does.
86 Red 944(sold) 85.5 Red 944(sold) |
meister member
I am currently doing a vette lt1 V-8 conversion and i frequent the hybrids board as well. There are some guys on there who can answer any and all questions about the swap. One guy who has a LS1 conversion raced in the Cannon Ball Run last month and did quite well. Hope this helps....
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
If you haven't already, check out www.ls1tech.com They have a forum specifically dedicated to hybrids. It may not answer this question, but will be very handy if you go the LS1 route...hands down the best LS1(if not all cars/engines) message board on the net.
1987 924S 2000 Camaro Z/28 |
I was seriously looking into that conversion. I spent a lot of time talking to the guys out there and they definately seem to know what they are doing. I had intended on having them pick up my 84 when they delivered a car to Ohio and then get it back in 6-9 months. I ultimately decided to go with a supercharger on a stroker bottom and build the suspension up to go along with it. I am just about finished. The blower is still to be dialed in on a dyno. I will realisticly only have around 200RWHP and about the same torque, but as light as it is I anticipate a huge difference. I also shaved some lbs w/ the Fiberwerks front and rear and Wilwood brakes. Renegade was looking at around $18-20K for a turn key using my platform w/ the suspension done already. I did not like losing power brakes at all and I also have heard of potential cooling problems when running A/C. All in all they seems like a firs rate operation and the cars look cool w/ that LS1 under the hood for sure.
Even w/ 200HP I am sure my winter project will be a 951 tranny and LSD. I already did the 951 sway bars and a lot of other heavy duty stuff. Good luke: Steve 84 944 "Schrittkind mit dem roten haar" 91 C4 98 M3 00 Durango 06 Aprilia
84 944 (my favorite all time car) 98 M3 (the wife's) ML55AMG 03 Eurovan 00 Land Rover Disco II |
I was in the Homestead 12hr race there was a 951 with a C5 engine. It started last because it was late getting up to grid. By the end of lap one it was in 3rd. It lasted 45min after blowing it's 2nd transmission of the weekend.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
