Send a message via AIM to jakemu24
return to idle
whenever i rev the engine or switch to the next gear the tach shows that the engine speed doesnt return to idle right away. so basicly it takes a few seconds to return to idle speed when reved. my old 944 would return to idle speed very quickly after it is reved. can i fix this by adjusting the idle speed. also the car returns to about 1100 rpm instead of the usual 900.
1985.5 Stone Grey 944-SOLD
1987 Yellow 951- For Sale
Old 06-17-2006, 10:39 PM
Eldorado's Avatar
run the car for 10 mins or so.. get it hot.. then try adjusting that idle control screw.. see if it fixes your problem..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-17-2006, 11:45 PM
If i pull the gas pedal out to close the throttle the idles will go back to 900 rpm from 1100. So would adjusting the trottle cable possibly help me? or should i just adjust the cable so the throttle is completely closed and then adjust the idle screw from there?Could the TPS have anything to do with my problem?
Old 06-18-2006, 02:52 PM
SoCal Driver's Avatar
Have to jumper between pins B and C on the test plug before you adjust the idle on later 944's. Check the throttle cable tension as mention above. The throttle possiton switch will give the early 944's idle fluctuation fits. Not necessarially the later 944's. Change in DME programming.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 06-18-2006, 03:15 PM
Eldorado's Avatar
good to know...
i know if my switch is turned too high so idle reaches 1100 or over, the idle will drop down to 500 then back up to 1000.. as it creeps back up to 1100 again, it would drop down to 500...
without even touching the pedal.
this was before wilk's chip, of course...
wilk's chip cures all that for me..
Kyle
Old 06-18-2006, 08:21 PM
OK, i just want to be sure. I shouldn't be adjusting the hrottle cable at all right? I should make sure it opens and closes with ease and work on the idle screw from there?
Old 06-19-2006, 07:33 AM
