Cars & Coffee Killer
AC Delete Bracket
There is no way in hell I'm putting my alternator back in the stock location. I'm going to delete the AC and move it lower.
My question is, there seem to be (at least) two different AC delete brackets out there: the one from Porsche and the one from Lindsey racing. Being that there is only a $10 price difference between the two, I'm curious about their relative performance. Is one better than the other? Why?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Writer/Teacher
I'd be willing to bet the Lindsey unit is a heck of a lot lighter (aircraft-grade aluminum, if I remember correctly). The Porsche bracket is simply a factory no-cost AC delete item.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
I haven't weighed them side by side but the factory part is thin cast aluminum and isn't very heavy at all, I doubt there is a significant weight difference between the two brackets. The machined and annodized aftermarket bracket does look cooler though. I waited for an aftermarket broadfoot bracket for 2 months before I got fed up and ordered the factory bracket.
Is there a good reason I shouldn't get the Lindsey one?
Writer/Teacher
Not unless you're one of those "gotta be OEM" guys...
Well...I just placed my order. Dave Lindsey must be loving me lately...
Writer/Teacher
Well, if it makes you feel better, I adore Lindsey racing... the fact that a good portion of the PCA club racers that I've seen at LimeRock heavily use their products makes me feel okay about ordering from them
Well, my new J Boot (and vacuum lines) came in yesterday, my A/C delete bracket is coming in tomorrow, and the shop just called and my alternator is rebuilt and ready to pick up.
Maybe I can have her running by the weekend!
You will be happy with the the lindsay racing one, I have the kit and its nicely made
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
I double-checked the projected arrival date for my bracket and it is tomorrow, not today.
![]() I did manage to get the old bracket off last nigh and pull everything of the AC system but the coolant lines... I found an immaculate radiator behind the condensor.
Looking for an ac delete bracket...used is fine...Thanks...
Me too!
What me speed? |
Toofah King Bad
Someplace on teh Cup forum is a DIY for this.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Garage Helper
Actually the no AC alternator mounting bracket came first in the early '83 models. Later AC was added to 60% of all '83's as an option. Then in '84 AC became a standard add-on. Still the same "Bullet Proof" bracket as issued by Porsche today, and it's shorter 5 rib Serpentine belt. In '85.5 the belt became a 6 rib Serpentine belt - in 5 rib or 6 rib belts the no AC belt is smaller on the diameter than the Plus AC belt. Other parts remain the same on both configurations, adjustment turn-buckle, and so on.
Almost forgot - The AC Delete Alternator sits much lower that if it has AC. So the cooling air ducting is different starting on the Alternator Cooling Ducting back cap. With AC the cap there aims down to pass the ducting around the AC Compressor - Where as the rear cap that is mounted to the back of the alternator on non AC cars, the ducting cap aims down then 90* at the bottom of the Alternator it turns 90* to face the front of the Engine - therefore the old style ducting plan is to have the duct pass very close to the bottom of the Alternator - and does snot dip way down any more to clear the compressor. Now wasn't that a crock - -
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 02-17-2012 at 06:49 AM.. Reason: Oops |
GorillaFoot
Just bought this one from Fast Guys for $125. Haven't installed it yet, but very light and solid
Fast Guys Superlight 944 A/C Delete Bracket Kit FastGuys.com |
I went the DIY route. The local junk yard gave me the adjustable alternator arm that I used. A bit of smacking with a hammer, one hole drilled, and a new shorter belt and I was good to go. $15 total cost and nearly no added weight.
But yes, the alternator is in the stock location. |
I broke down and got the 5 guys as well....i mean fast guys....
What me speed? |
Location: In a dumpster behind Albertson's in Los Angeles County
Very nicely done piece from Fast Guys, I have installed a few of them....extremely light and high quality.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
your average wrencher...
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
