nige944's Avatar
Automatic speed control
My 951 allegedly has Automatic speed contol, i'm assuming this is cruise and not something else, if thats the case how do you use it?
I'm not stupid but i dont seem have any switch gear for it, although i do have a suspicious square hole on the steering wheel column beneath the wipers.
Guess i'll have to read the manual...
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 08-15-2006, 09:12 PM
Eldorado's Avatar
look at the throttle body (the pulley where your gas pedal line connects to)... if there are two cables coming off of the top of it, then you have cruise...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 08-15-2006, 09:49 PM
nige944's Avatar
Ok I do have cruise.... but no steering column control.
Old 08-24-2006, 07:37 AM
GostRidr's Avatar
Bummer! That hole under the windshield washer arm USED to house your speed control arm. Can you tell if it was snapped off versus removed for some dumb a$$ reason?!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 08-24-2006, 09:05 AM
nige944's Avatar
I've been averaging a couple of hours a night fixing and troubleshooting my emissions problems recently so i havent really looked.
From the diagrams I've seen of the part, its a combo wiper/lights/cruise piece, so i'm not sure if you can remove the individual levers without snapping them off.
Old 08-24-2006, 09:27 AM
GostRidr's Avatar
Nige,
I did a little digging on the PET. My car has two stalks on the right. One for the washer and one for the speed control. Unfortunately, PET lists one part for the whole mechanism including ALL the stalks. Check out Group 9: 903-02
good luck with the emissions!
peter
Old 08-25-2006, 12:13 AM
nige944's Avatar
Thought i'd fixed the emissions yesterday, but it still wasn;t right as I couldn't get it to idle anywhere close to 840 unless the screw was all the way in.
So i screwed it all the way out and could hear hissing from near the turbo boot, so i decided to take it out and have a look, and discovered that.
One of the hidden vacuum connectors was zip tied in, rather than the circular pipe connectors.
There was a large rip at the MAF end.
Oh and the blow off valve came away in my hand, with part of boot attached.
So time for a new one... Let hope this IS IT!!! :-)
Old 08-25-2006, 05:31 AM
GostRidr's Avatar
Is this what you need?
http://cgi.ebay.com/ebaymotors/PORSCHE-PARTS-944-968-STEERING-COLUMN-SWITCH-CRUISE_W0QQcmdZViewItemQQcategoryZ50459QQihZ014QQi temZ330019446589QQrdZ1QQsspagenameZWDVW
or, ebay item number 330019446589
peter
Old 08-25-2006, 09:40 AM
