Certified Rennwerker
DME temp sensors ??
I need to know if I did this test correctly. Using my ohmeter on the blue sensor on the block I connected to terminal 13 at the sensor and on the plug. Tried both posts on the plug and sender and my meter reads .0L. No matter what I connect to no reading at all. Book says to check at the DME plug but I used the plug at the sender.
Did I do this right and have a bad DME temp sensor? tia! Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
If you have the meter connected at both posts on the sender and it reads .0L
Its toast
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
One to ground the other to the terminal post. Checked each terminal on the plug and the sensor.
Dal
