will not maintain idle, or run at hi throttle
my 87 na had an alternator replaced, and the p.s. pump brackets repaiered.
Now, it will not idle, just dies like the gas or spark is cut off. also, if you try to keep it at hi rpm(2000 ish..), it will slowly lose rpm in about 5 seconds, and die. i can drive it if the pedal is active in moving the car thru the gears, and sustain a higher rpm, like abouvre 2500 rpm. fresh fuel added to tank. i will be moving the car 20 miles to home tomorrow, and would like to fix it. ideas appreciated. tahnks tom
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
well, as you see, i did a search.....
vacuum leak.
if you can keep the car alive with the gas... that's my vote.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
thats my initial guess too. it used to run just dandy.
will know more when she is home. last time i tried to dx it, it was over 100 degrees in K.C., sweat burning my eyes.
My guess: TPS (throttle pos. sensor). it has idle, throttle, and Wide Open Throttle settings.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Todwic is alive!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
my car had similar symptoms when i changed out the airbox. although im the last one that should be giving advice around here, i second the notion for vacuum... in my case the car would start, i could rev it but it would immediately trail off and die.
what it ended up being was a vacuum line that connected UNDER the intake J-boot.
1995 993 C2 |
Certified Rennwerker
Well based on the repairs I would guess the Alt belt is not up to tension and slipping causing the Alt to not produce the proper energy to run properly, poor spark- poor idle, not enough current to run the FP.
When running and the RPM's are increased the belt will tighten up. As the belt tightens so it slips less if any giving the alt the ability to generate the energy thus at high rpm it runs fine. Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
some great problem solving thinking going on here, will get you the results on Mon.
thanks!!! tom
eldorado, EMBpilot, its alive~!!!!
well, guys, i forgot to thank you all for the input. It sure looked like that bottom vacumm line was on the nub, but it wasn't.
After i put the new alternator on, the hoses were somewhat rearranged, but it looked to be on. i had to spray the line with silicone, then rearrange the lines to get it on, its quite a stretch, and its hard to tighten the hose clamp in cramped, underside, out of sit quarters, the metric way.
