Old 928 Guy
surfdog4's Avatar
Another Vote for the Throttle Response Cam
Well i just installed the round throttle reponse cam..and I like it. It definitely seems to make the car feel more "sporty" in regular driving.
I haven't had any issue with it being "jumpy" in stop-and-go traffic like some folks have discussed.
I would recommend folks give it a try..if you mod the existing cam it won't even cost you anything...installation was very easy
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 12-19-2006, 06:52 AM
White and Nerdy
Tervuren's Avatar
Re: Another Vote for the Throttle Response Cam
I actualy find it easier in heavy traffic, just a small touch of the throttle when you suddenly need to get moving again, or suddenly need to accelerate to change lanes, etc.
For performance driving though, I prefer a more linear throttle offered by the standard cam. If I'm just trying to be aggressive in traffic on the road, the throttle response of my brother's '86 is great, just feather the throttle to be zooming when needed, cuts a lot of time.
My driving style though, involves a lot of subtle throttle moves throughout sections of a corner, rather then a sudden punch, so I prefer it to be linear so I have more control. All a matter of driving style.
Shadilay.
Old 12-19-2006, 07:46 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
in actuality, the throttle cam mod or replacement cam is 'linear' where the original cam has kind of a two-stage curve to it. the initial part moves the throttle less (on a curve)... due to the larger, yet decreasing diameter of the circle that it makes. toward the end of the travel the cam changes, it is a smaller constant-rate circle that provides faster opening of the throttle in a linear fashion.
the replacement cams or modded ones are simply a constant-diameter circle and provide a linear throttle opening
that said, i've used both and i find it easier to drive more smoothly on the street with the stock cam, as smaller corrections are more easily made. on the track however i would probably go for the modified or replacement cam since it would take less time to go to WOT.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 12-19-2006, 08:45 AM
thoen's Avatar
i heard that a round cam is makeable? i see the prices going from $26. (performance parts) to $40. on ebay. i guess there is no difference? so how can you mod it for free unless you make one yourself??
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 12-19-2006, 08:56 AM
Old 928 Guy
surfdog4's Avatar
there are at least two versions of "make it yourself" i dont have the links here but if you do a search you will find them...I ended up buying the one because I wanted to have the stock one intact in case I sold the car some day
Old 12-19-2006, 09:09 AM
thoen's Avatar
Thanks.
I will buy the $26. (weltheimer(sp?)) from performance. i will update your post when i get an opinion out of it!!!
Old 12-19-2006, 09:18 AM
thoen's Avatar
i found the article on how to modify the cam:
http://www.dietersmotorsports.com/tech/2001/944_throttle_cam.htm
Old 12-19-2006, 09:38 AM
Send a message via AIM to hpaulb
Is there any gain on doing this to an automatic? I have an extra can and can fool around with this in the winter. Also, how do you take up the extra slack in the cable length. I would assume you'd have to adjust the nut by at least an 1/4 inch. Doesn't look like any change in the picture?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 12-19-2006, 09:55 AM
White and Nerdy
Tervuren's Avatar
However, the valve is not linear, so you want a non linear opening of the valve to attain a more linear amount of actualy flow.
Shadilay.
Old 12-19-2006, 10:41 AM
Dana Norris's Avatar
My current 944 which I just bought 3 weeks ago, has the modified cam.
My last 944 an 1984 model was stock, the current car does seem a bit sharper upon step in, but has anyone experianced a higher idel RPM?
My 86 idels at about 1200 RPM.
_________________________________
1986 944NA Black with Burgundy Leather
1984 944NA Garnet sold to a Corvette owner in1993
1969 912 modified with 1974 911 2.4 CFI sold to a guy from Alaska
1976 911S modified with 1983 911SC 3.0
Old 12-19-2006, 11:42 AM
That Guy
Techno Duck's Avatar
Automatics benefit from from the throttle cam also, however because you have the extra kickdown cable, you need to make a slight modification to any cam you purchase. Either that just make it yourself.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-19-2006, 03:00 PM
ERAU944's Avatar
high idle is probably caused by an out of adjustment throttle cam. you should hear a click when the throttle closes (the car doesn't have to be on to hear it). also, when you install the cam, the pedal stop is also supposed to be adjusted so that you don't stretch the throttle cable by pulling harder than would do any good.
it sounds to me like whenever the cable got adjusted at the motor side, it was adjusted too tight. see if the switch clicks, if not, loosen the cable just until it does consistently.
Old 12-20-2006, 05:16 AM
Old 928 Guy
surfdog4's Avatar
yes you must adjust the cable to accomodate the new cam...at least on 85-2's and beyond the adjustment is right near the cam where the cable clears the sleeve..I read on earlier ones it is on the firewall.
If your idle goes up after the cam swap then you need to give the throttle cable some slack.
You also may have to adjust a large plastic bolt that lives in the floor pan behind the accelerator pedal so that the pedal hits it before the cable is pulled completely taut. It's actually easy to get to.
Old 12-20-2006, 06:11 AM
1984 Porsche 944 Throttle Cam
I got a used cam from the PO of the car. I am not quite sure where you adjust the extra cable on a 84 944?
Please help.
Old 12-20-2006, 04:17 PM
Old 928 Guy
surfdog4's Avatar
the instruction sheet i got with the new cam said that on pre 85-2 the throttle cable adjustment was where it came through the firewall..that's all i have
Old 12-20-2006, 05:10 PM
Politically Incorrect
onZedge's Avatar
No comment.
Edek
'87 924S
'91 535i
Old 12-21-2006, 04:26 PM
thoen's Avatar
i just put on the response cam. NICE difference but Small difference. I am glad i did it just for the initial response when the foot goes on the gas.
Old 01-07-2007, 09:10 AM
I installed one last week, and my N/A now puts out 15 HP more than before the install. I'll post the dyno charts after I scan them in.
Red 1967 Saab "96", needs help
Blue 2002 Pathfinder SE
1991 240SX-SE, auto, trans was shot - junked it
Old 01-07-2007, 01:20 PM
that dosent make sense it shouldent give u hp
Old 01-07-2007, 01:54 PM
Rrrockhound's Avatar
I believe that was sarcasm.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 01-07-2007, 02:38 PM
