Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Question Trouble Codes?
Is there a way to get trouble codes from a 1987 944 NA? It has the Diag. Port so I am ASSuming that you can potentially hook up a scanner and get trouble codes and engine read-outs.
I know in GM cars with OBD1 you can bridge the connector pins and the check engine light will flash a number of times and pause a number of times giving you a trouble code to help diagnose problems.
Would this be true on the '87 Porsche? I know computer scan tools were not really used in the late 80's, not until 1990 did it really be used.
Just wondering...
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 04-03-2007, 10:10 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Porsche made a specific diagnostic tool to attach to that port but the computer is not OBD compliant.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-03-2007, 11:33 AM
fast924S's Avatar
Send a message via AIM to fast924S
I wonder if any one has a scanner that would work on it
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 04-03-2007, 11:34 AM
SoCal Driver's Avatar
Supposed to be a diode or be able to span two of the pins with a diode and read a blink code.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-03-2007, 11:47 AM
Gremlin85's Avatar
Any site or list of these codes?
I wanna try out the diode and see if I can get anything from it.
Old 04-03-2007, 02:47 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
i just read a panorama and/or post with information on this.
i'm thinking it was the last issue or the one before that... there was definitely an article in pano. check it out!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 04-03-2007, 08:01 PM
Gremlin85's Avatar
I don;t have a subscription to the pano.
Is there a way someone could post the article?
P.S. TPS is fine, clicks and all... see last post of "Now I've done it..."
IAC?
Old 04-04-2007, 10:06 AM
