ae1969's Avatar
Send a message via ICQ to ae1969
Originally posted by ae1969
When it fails.... tap the dme.
More than likely bad soldering point on the ignition driver....
TA-DAAAAAAAAAAAA .........
........ you are better off re-soldering the entire thing at this point........
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-22-2007, 04:07 PM
Eldorado's Avatar
was that an "i told ya so" ?
subtle, alex.. real subtle. :P
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-22-2007, 04:57 PM
Good to hear that you possibly got it fixed. I am just South of you near Macalester but finished school a couple years back. I only drive the 944 a couple days a week, so if you see a guy in a black 944 or a new silver GTO wave its probably me.
'84 944, '05 GTO
Old 05-22-2007, 07:17 PM
I've been driving heavily for a few days now and now problems whatsoever. It also starts right off, where it would always chug for a few seconds before, even when it was starting properly. I don't want to jump to conclusions, but I'm hoping this is it. I'm finally enjoying my 944 with little anxiety. Thanks, everybody.
Pete
1987 944, Silver
Old 05-25-2007, 09:17 PM
So I got the car back from the mechanic a while ago, over a week, and he had soldered in a new pin in the DME or relay or whatever in that assembly has the pins, because the pin that controls power to the coil was burned and it was arcing. As soon as I got the car back I noticed that it fired much quicker when I started it, especially after it had run recently. Over the last couple of days, starting time has increased to a couple of seconds and now the damn thing has gone back to not starting periodically. Of course, it has yet to fail when I actually have my tools and gauges with me. I'm thinking I should bring it back to the mechanic and find out if that same pin is burned once again. Am I right in thinking that a problem with the DME may be causing the pin to burn? (If indeed it is burned again)
Pete
1987 944, Silver
Old 06-02-2007, 03:45 PM
winter-hater club member
nynor's Avatar
too much power draw at the coil or something?
"COOL PRIUS!" - Nobody Ever
Old 06-02-2007, 03:47 PM
If I weren't leaving out of town on Monday and Grand Ole Days wasn't tomorrow, I would gladly lend you a hand figuring it out as I fought this same battle about a year ago. Hopefully your mechanic can get to the root of it as it sounds like the pin may not have been the culprit after all.
'84 944, '05 GTO
Old 06-02-2007, 04:05 PM
I'll be at Grand Ole Days too! Well, if Metric can't solve it, maybe i'll send you a pm and we can work on it.
Pete
1987 944, Silver
Old 06-02-2007, 11:34 PM
My track buddy had a similar problem: the harness had an ever-so-small bare spot that rubbed against the block in the rear of the engine, between it and the firewall. Cost him several thousands of dollars to find a 2 cent fix. His was cutting out whenever it touched.
Old 06-03-2007, 08:33 PM
Send a message via AIM to deekay911 Send a message via Skype™ to deekay911
Why wouldn't you buy a new DME to fit? Must have cost you more than that by now. I keep a spare one in the glove box of the 964 and the 968.
DK
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 06-03-2007, 09:31 PM
DK
Hasn't cost much more than my sanity so far. How much is a DME? I hear not cheap at all.
Pete
1987 944, Silver
Old 06-03-2007, 10:10 PM
Eldorado's Avatar
a dme wouldn't fit in our glove boxes. lol
Kyle
Old 06-03-2007, 10:18 PM
Send a message via AIM to hpaulb
Spend the time on following the harness. It's pretty small. If the pin is burned again, you have a problem internally or externally. Also mechanics are all thumbs with a soldering iron. Remove and take it to a electronic service shop. Have them go over it and resolder any suspicous solder joint. There use a large magnifying glass. Just tell them it's from somthing otherm than your Porsche or the price doubles?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 06-04-2007, 08:04 AM
O' take the schmatic in with it. There's lots of copies around.
98 BMW 740i
Old 06-04-2007, 08:06 AM
Sounds like you're on the right track if it worked flawless for a while.
Are your saying the mechanic soldered the DME or the DME Relay? If you're not sure you better find out. You can do the DME soldering yourself but if it was the DME Relay it's just better and cost effective to just get a new relay.
Here is a web tutorial that will point anyone that wants to solder the DME in the right direction. You can thank me later ;^)
http://www.rennspeedracing.com/DME_tutorial.html
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 06-04-2007, 10:36 AM
SoCal Driver's Avatar
Really???
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 06-04-2007, 11:29 AM
UPDATE: Mechanic pulled the DME out and checked the pin he re-soldered. It's still good, not burned like we thought it might be. So the problem persists. He has suggested replacing the DME. This, I can do myself. I'm picking the car up tomorrow and it's back to the drawing board. Does anyone have a corner on a re-manufactured DME? Thankfully I have a new motorcycle, so I can get around without the car, but the only way for me to solve it is to drive it regularly, which I can't do when i need to work. So...I'm leaning towards just replacing the DME. I've heard this isn't cheap, so let me know if you know where I can find a re-manufactured one. Thanks.
Pete
1987 944, Silver
Old 06-11-2007, 04:27 PM
nynor's Avatar
i'd try borrowing one, first, to see if it is the problem.
Old 06-11-2007, 06:07 PM
74goldtarga's Avatar
Hello Pete,
I live in Bloomington, I don't know anything about the electrical system in these cars, or any car for that matter. Auto-Edge in Mahtomedi is the undisputed champ as far as expertise on these cars in this area. If you can't do it yourself, and your shop can't fix it, then let them help you. They aren't cheap but they are fair and honest and have an excellent reputation among PCA members who race/track their 944's. They have worked on my car briefly up at BIR and they do a nice job.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 06-11-2007, 07:11 PM
Send a message via AIM to olivar
from my electronics expeirence,if that pin keeps burning out,that would indicate a short somewhere down the line,if you try another DME and it does the samething that would be the best bet.FYI
Old 06-12-2007, 08:07 AM
