Burping out of my overflow....
I'm having issues with my n/a 944 burping coolant from my overflow. It runs fine heat works fine and there is no oil/water mixing issue at all. The car runs normal temp wise it just seems to all of a sudden burp some coolant out of the overflow tube... I'm worried it's a headgasket but like I said theres no mixing and it's not overheating....Any ideas? I just paid big bux to have the cam tower gasket done, I hate to have it all torn apart again for the head gasket....
1986 944/NA 2004 Yukon on 20's (Bling Bling) 2005 Durango Hemi Last edited by fastang; 06-10-2007 at 10:22 AM.. |
winter-hater club member
have you tried a new radiator cap?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
I agree with nynor - my old 924 lux would do something similar - as soon as the engine warmed up she'd start to dribble coolant out the breather hose.
A new rad cap solved it.
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
Back from Beyond
Do your coolant hoses become quite stiff after the car runs for some time? You may have a head gasket problem after all. But I agree with these guys - try a new rad cap first. Mixing of fluids doesn't always happen when the head gasket goes. I know - mine ran this way for a long, long time. Finally I got sick and tired of it and changed the head gasket. Solved.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
I bet it's the cap. generally it will overheat immediately and often if it is a headgasket.
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
One more vote for the cap. My car had the same problem when I first bought it. Hopefully you're in for the cheap solution. I recommend buying a cap with a flip tab so you can vent it if you ever need to.
1987 924S 2000 Camaro Z/28 |
Thanks guys I'll give the cap a try....I'll keep you all posted...Do you guys run you cap at the first click where it's still a little lose or all the way tight?
1986 944/NA 2004 Yukon on 20's (Bling Bling) 2005 Durango Hemi |
a cap is a cheap experiment.
Back from Beyond
All the way tight. The cap, that is...
