A/C refrigerant recharge
I am having trouble recharging A/C on my 944S2. I assume that the low side port is on the line along the driver side fender between the sighting glass and the point where it goes into the dashboard. The port is pointing up with a black cap. I used an old can of R12 and an old recharging kit. I run the car with A/C on and connected the charging kit. Nothing Happened!! Freeon is not going in!! What could be the problem? Am I using the wrong port? I do not see anything to push the valve down after the kit is connected to the port. Is the freeon pressure in the can supposed to be high enough to get into the A/C system?
Thanks. |
When I do what you're doing I stand the freon can in a bucket of warm (not too hot) water. This helps the freon get from liquid to vapor and provide pressure to speed up the process. It does take a while and you need to be sure that your compressor is cycling on
Andy D. Currently driving 2005 Audi A4 Currently driving 2006 Ram 1500 sometimes |
Greasy Member
Is the clutch engaging and compressor turning?
The low pressure switch should activate at 20psi. I have seen a couple of those little charge tubes where the "pin" fell out. If the center pin is not present, it can not press the valve open on the low pressure fitting, thus not allowing the refrigerant to enter the system. -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
That could be it. I do not see a center "pin" in the charging tube.
I think the compressor is on since I can see oil like streaking pattern through the sighting glass. Any idea where I can get a replacement "pin" or charging tube? -Jim
1989 944S2 |
hi, while we're on the subject, how do you know which type of refrigerant you need and where do you get the old stuff?
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked ![]() |
Greasy Member
Jim, Napa carries the short charging tubes for less than $10.
Wander, If you were closer I'd have you stop by my shop. I have probably 50lbs of R-12 in bulk cans to use in my A/C service machine. You can pick up the 12oz cans on Ebay, but you have to provide the seller with an EPA certification number. If you need a couple of cans, let me know, I'll get a couple of cans using my certification then ship them off to you. Let me know -Nick
Thanks, Nick.
I got 8 cans of R12, along with the defective charging tube, from a friend. I will stop by a store and look for those old style tubes. Where are you in Indiana? I am in Chicago. Thanks a bunch. - Jim
1989 944S2 |
I have been having good luck with Johnsens Freez 12. Manufacture claims it is fully compatible with r 12 sys and can be used to top them off. Any body else have any experience with this stuff?
Nick, thx, how do I know if i need the R12? does it say somewhere on the car? or a/c system?
all the 944's take R12, unless a previous owner converted it.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
winter-hater club member
i bought some duracool off of evilbay. will work with r134a or r12. i figured that i have no idea what the previous owner put in there, so it should be compatible.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
sounds good thx
Re: A/C refrigerant recharge
The low side port is on the compressor.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Thanks, bazar01. The port with the black cap is indeed the high side. YOU MAY HAVE SAVED MY LIFE!!
Where is the compressor on this 1989 944S2? Do I have to approach it from underneath the car? |
yep. bottom driver's side.
