How to delete the Catalytic Converter
My neighbor told me that the best sounding 944 he's heard was with stock exhaust and the catalytic converter removed. I'm sure there are opinions about the muffler but at this point I am going to stick with stock and just try the cat-delete.
I thought I would try this out and I'm wondering what is a good source for the cat-delete pipe. I'm assuming I can just unbolt the old and replace with a straight pipe (I haven't really looke under there lately but I assume it bolts into place). Anyone who's done this, will this have any effect on how the engine runs - of course, I will replace for my emissions inspections. Vern |
Last I looked it was welded in place. I think the best route would be to cut the old one out and bolt in a high flow cat. Legal yet better.
1987, 944S (168,000 miles)..sold 1986, 944na. My job is a hobby. My 944's are work. |
I 'm pretty sure that the cat is welded to the down pipe from the exhaust manifold, but it connects to the muffler section with a 3 bolt flange.
Never done it but I have heard of people doing this, also just "gutting" the existing cat. I don't know how your welding skills are but most folks just take it to a competent muffler shop to have one made up.
Rob 87 944 * 89 951 "When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car." |
The exhaust manifolts bolt to the first section of exhaust pipe (with the 02 sensor, test pipe bung, and cat), which bolts to the rear section with the muffler. I'm going to take a used first section, cut the cat out, weld in a piece of pipe, and install that in place of mine. Then if I need to swap in the cat, it will be easy.
-Gabe -black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her -1987 MR2 ---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON--- |
I like blks response, the cats are valuable, especially for resale to a state with emissions testing. Cutting yours out would make it worthless.
'74 911 Targa - Sold to the highest bidder '87 944 Turbo - Fix for track addiction '72 DeTomaso Pantera - Sold to the only real bidder |
It's actually pretty easy to cut the cat out and weld in a straight pipe. I love Michigan, no emissions laws here!
2006 Porsche Cayman S 2006 Lotus Exige (Sold) 1986 Porsche 944 (Sold) 1981 Porsche 931 (Wrecked) 1987 Porsche 944 (Sold) |
I just punched the guts outta mine. I think it sounds better, it really sounds pretty good. Some people think it makes more resoance in the cabin when you do this. I'd have to say it has just a bit more, but not enough to be anoying in my opinon. Ideally you could put a perforated core glass pack in place of the cat and weld the converter shield around it and then it would act as a low restriction premuffler/resonator/dummy cat. That is what I have planned some day for my car. So that's my two cents worth. I also think that it seemed to run a little better and rev a little freer. It seemed to take care of a flat spot up top.
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
personally I liked the sound of the cat w/o muffler better when I did mine. Here is what it sounds like w/o cat and with original muffler.
http://www.youtube.com/watch?v=gYvr3k5kkmM&mode=related&search= this one is the best representation of what it will sound like w/o cat. Not my best run
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
Sounds pretty good. Did you gut your muffler similar to what Speedy did or did you just put a piece of straight pipe on it?
Cars & Coffee Killer
I used a sharpened three-foot piece of rebar, a sledge hammer, and a shop vac.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I have read some about this. Don't gut the cat you can potentially lose power by doing this. You would only gain power if you had a cat that was clogged. I have read that when you gut the cat it will create turbulence. Either delete the cat all together or get a high flow cat.
87 924S-Hoping to supercharge 84 Rz350-Has a couple mods 71 CL350-Doesn't run |
Not having it helps the spool-up on a turbo.
I did a cat-delete 3 weeks ago...switched over to a stock muffler. Sounds easily 10x better than a beefier muffler+cat...
Not so much a 'VRROOM' anymore....now its more of a 'VRRRROOOWWWW' lol
'86 Porsche 944, Guards Red Nancy is currently [going in for the final 'once over' this week..] AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL |
yes, on a normally aspirated engine you can lose torque - you might pick up a pony or two up top though
the bigger issue is what it does to the mixture - removing it changes the back pressure, and consequently the reading the O2 sensor gets - this can be damaging |
Burn the fire.
Get one of Russell Berry's chips, remove the CAT and/or replace it with a glasspack. Go with a turbo muffler. Sounds mean, not ricey.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
I removed most of the cat with a stick ... i used the garden hose to get the rest...
But in all seriousness.... its pretty easy to remove the cat... i did so on my Beemer and had straight pipes put in... got bloody loud tho... but that was a six with dual exhaust. Sounds very mean tho.... you can also get resonators that look like cats, theyre essentially just a straight pipe that has a bulge in it.. holds a little pressure due to their design on the inside which can help the torque loss you may incur..but also gives a high end power gain...
Marcone ~87 Turbo ... Vandalized.. now a parts car. ~89 s2 16v ... Getting back on the road soon. ~89 Turbo S ... I GOT ONE.. Hidden away in storage!! ~04 Cayenne S ... |
I gutted my cat.
I stopped driving it because it sounded that bad. I replaced it with a straight pipe, much better.
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
where could i get my hands on one of these resonators and how much would it cost???
Umm..
not too sure in the states. ... but in canada i got a resonator for like 59 dollars at a local muffler shop. they installed it and everything for another 50. Lots of shops make them. just have to find the little shops that do basically the inside of it looks like a cheese grater, so you can recognize one if you see it. Hope that helps a little
