gt350mike's Avatar
Question Difference between 85.5 and 88 N/A???
We're thinking about buying another 944 and I have narrowed our search to two N/A's (85.5 and 88). The 85.5 has less than 60k miles but it still has the original clutch. The 88 has a new clutch (less than 10k miles ago) and has about 100k miles. Both cars have un-molested and have been taken care of so our decision to buy one or the other has been difficult.
My question is what are main differences between the two model years????? Any guidance on which car we should buy???
Thanks!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-18-2007, 05:58 PM
p-talk's Avatar
I know the 85.5 still has the early offset style front suspension with stamped steel instead of aluminum arms in front. If you'll need to rebuild the front end the price difference is HUGE, and pretty inexpensive for the early cars.
My 0.02 . .
Thanks!
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 10-18-2007, 06:58 PM
That Guy
Techno Duck's Avatar
Actually all cars after '85.5 came with the aluminum arms, it was still early offset though. You can retrofit, or 'backdate' to the steel control arms though. With early offset you can fit basically any OEM Porsche wheel to your car with the correct spacers.
Other than the suspension differences the '88 has slightly higher compression, i think 10.2:1 as opposed to 9.5:1. This equates to maybe 10hp max over the early cars.
Tach will have the MPG gauge
The '88 also has a different 5th gear ratio, often referred to as the 'short' 5th. The car revs a little higher in 5th gear but accelerates better in that gear. It makes 5th gear a little more 'usable' without having to downshift to 4th all the time.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-18-2007, 07:13 PM
p-talk's Avatar
Sorry, my bad, I didn't realize the '44s got aluminum arms before the offset switch.
*snip*
Old 10-18-2007, 07:27 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I'd go with the 85.5 for the reasons already given. The control arms, struts, and strut bearings are all different for 87-88 and SIGNIFICANTLY more expensive, and you can't Fuch an 87-88. The only reason to go with the '88 is if the extra compression and power are worth it to you, or if it has ABS and that is important to you.
Yes, the 87-88 front end is supposedly more durable, but you can rebuild the earlier style twice for less money than renewing an 87-88 once.
nate
1988 944... and a bunch of other cars
Old 10-19-2007, 06:34 AM
Proprietoristicly Refined
John_AZ's Avatar
Your son has a '83 944 and you had a '87 944-RIP. Your view of the interior and exterior might give you a better perspective. 60K miles on a '85 is not unusual but since the odometers often fail I would check to see if the odometer case has been opened. If both have been taken care of, the shocks and other easy replaceable parts should have been changed. The rubber clutch disk-'85, will fail sooner than later. If both look good-I vote for the 1988.
John_AZ
1988 924S 57K miles
1987 924S 111K miles
Old 10-19-2007, 08:49 AM
gt350mike's Avatar
Thanks for all of the comments........We're heading out tomorrow to look at both cars. I'll keep y'all posted on the outcome.
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-19-2007, 07:35 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
The '88 will also have air bags (PITA), ABS (PITA) and the spring tensioner on the timing belt (PITA).
However, it will possibly be newer and fresher.
Black Cars Matter
Old 10-19-2007, 08:58 PM
gt350mike's Avatar
Are airbags standard on all 88's? This 88 does not have it.
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-20-2007, 06:47 AM
I thought it was standard on '87 and higher. Might have been removed. I believe the 944 had the distinction of being the first car in the world to have standard driver and passenger air bags (in 1987), but I could be incorrect.
Check under the hood for big yellow "capacitor" looking things - they're part of the air bag system. If the P.O. disabled or removed the system and left those, at least it'll give you a hint of what's been done. There may be an option code to check also - check Clark's.
Black Cars Matter
Old 10-20-2007, 06:56 AM
Beau's Avatar
Send a message via AIM to Beau
I have an '87, no airbags. I've heard they were standard starting in 1988.
1987 944 NA
1984 911 SC
Tyler Durden theory of Porsche ownership: "The things you own, end up owning you."
Old 10-20-2007, 02:32 PM
gt350mike's Avatar
I found another 88 N/A that is about 600 miles away. It has less that 75k miles and it has been well maintained. So I think my choices are the narrowed down to:
1) 75k miles on an 88, well maintained, new belt & tires.
2) 110k miles on an 88 VERY detailed maintenace records for the past 15 years (most of them are from the local Porsche dealership. The clutch & belts have been replaced w/in the past 10k. It also has 968 wheels.
3) 60k miles on an 85.5, also well maintained.
Both of the 88's are at the same price; If I bought the 88 w/75k miles I can buy & ship it for the same as the 88 w/110 miles. The 85.5 is about $500 less. This will be our third 944 and you would think I could make up my mind but I'm having a tough time deciding on which car to go with. Any guidance/recommendations before I pull the trigger would be greatly appreciate it!
PS - Don't think I have a garage full of 944's, I left out one little tid'bit............I took my car son's 83 two week ago and I had an accident that resulted in smashing the front radiator core support. The car is totaled because it will cost about $2k to repair the damage and I don't have time to work on it myself (I've been activated with the National Guard). To say that I feel lower than a plebe is an understatement.
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-21-2007, 10:34 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
My vote is the 88, but then again maybe I'm biased. For the record, in 88' airbags were an option on NA's and standard on S and Turbos. Same with ABS. Mine has neither.
It dosent look like you can go wrong with any of those choices. The 88's may handle a bit better because by then they were throwing on turbo parts when they ran out of normal pieces. Mine had turbo front sway bar but soft springs and stock rear. The motor also has some better baffling in the oil pan, it holds more oil (7qt), and has a few other tweaks like higher compression. The exhaust is a larger diameter and the muffler is twice the size (seems like it anyways).
The suspension is more expensive to replace than steel arms (you would have to backdate the 85.5), however rebuild kits now make it much more reasonable to repair the balljoint.
It dosent sound like you can loose, go with the one you feel the best about.
-Greg
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 10-22-2007, 07:03 AM
My '88 does not have air bags or abs - it was optional on the '88 n/a and standard on the turbo.
Old 10-22-2007, 09:38 AM
gt350mike's Avatar
We bought the 88 with 110k miles. I'll see if I can post a photo of it in a few.......
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-22-2007, 07:25 PM
gt350mike's Avatar
This was taken by the seller several days ago. I love the 968 wheels!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-22-2007, 07:42 PM
John_AZ's Avatar
Verrrry nice. Exterior very well taken care of for a 20 year old. I wish my chin looked as good as the front of your car.
John_AZ
Old 10-23-2007, 08:25 AM
p-talk's Avatar
Beautiful! And yeah, the 968 wheels look great, especially with the subtle grey paint color.
Old 10-23-2007, 09:22 AM
gt350mike's Avatar
I know someone might call BS on this, but the company that sold the car to me stated that an older couple (early 70's) had the car over 15 years....he also had the couple's 89 BMW 535 with 370k miles that was traded in the same time as the 944.
The 88 is a great example of an unmolested 944!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 10-24-2007, 10:09 AM
Nobody Special
All the cars you mention sound like solid 944's. I do find it odd that of the first two one needed a clutch and the other was done before 100K. Unless they were used in commute traffic or hilly areas even the rubber centered discs usually lasted much longer than than. I replaced my 83 at 161K and it still had lots of friction material left; the rubber center was shattered though.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 10-24-2007, 07:40 PM
