Baza's Avatar
Question Part numbers?
I am looking for the part numbers for the foam seals that seal the vents to the dash. I have removed my dash to get it re-coved (sic of the cracks) and found that all the foam seal are toast. I can not find a listing for these seals so has anyone replaced these and if so do you remember the p\n. The one I am looking for is located in the center under the stud that holds the dash on its for the demister vents.
Thanx in advance
Baza
Always start with the cheapest option first
83 NA Guards Red ( Home at last)
2011 Triumph America
Old 11-03-2007, 04:57 AM
robs944's Avatar
Hey Baza,
Not sure if/where you can find the OEM seals for the fresh air blower vents.
Only suggestions I can offer is either use some 3M foam with the adhesive backing (available at most home improvement or auto stores)
Or you check ebay for some vents that have good foam on them. Here is one auction that he's selling 83 trim pieces including the fresh air vents.
Item http://cgi.ebay.com/ebaymotors/PORSCHE-944-INTERIOR-SWITCH-TRIM-PACKAGE_W0QQitemZ290176888983QQihZ019QQcategoryZ33 705QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Not sure on the color of your dash but it's worth a shot.
BTW when you have it all back together I would like to see a picture.
Good Luck
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 11-03-2007, 06:39 AM
Baza's Avatar
Thanx ROB
I totally forgot about 3M products to caught up in the get the right part for the job thing.
Here is what the dash looks like now
I'll post when finished I have some ideas I want to try out so it could take a while looking at FEB 08 for completion.
Old 11-04-2007, 01:08 AM
