Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Need Help - Swaybar Bushing
so my car is on jacks, my sway bar is off and my bushings are the wrong size.
Going by this breakdown here:
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=944_USA_82_85_KATALOG&Illustration=402-05&Line_Item=4
it offers more than one size. i dont know which size i do need. i have no way of measuring my swaybar. does anyone know what size is on an 84'?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 01-02-2008, 06:41 PM
That Guy
Techno Duck's Avatar
As long as your car does not have the factory sport suspension, it should be a 20mm front i believe. The best way is to measure it though. You can pick up a cheap vernier caliper from Home Depot or your local autostore for less than $5-10.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-02-2008, 07:24 PM
Custom User Title
Dave L's Avatar
or just grab a 20mm wrench, if it fits closely you gots a 20mm bar
(be sure to try a few larger or smaller just to be sure)
Old 01-02-2008, 07:51 PM
Misunderstood User
Should be part number 477 411 053G 20mm
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 01-03-2008, 11:42 AM
Rockin' NW Arkansas
thats what im figuring. i ordered the 24mm on Pelican just by a guess. When i called to see if i could change it, i got the rudest guy who was no help.
i cancled the order and just ordered them from Autozone locally.
Matt
Old 01-03-2008, 03:51 PM
Regarding the sway bar busings. I just installed a 968 M030 bar on my car and to my surprize, it used the same bushing mounting bracket. So, I am assuming that as you increase bar size, the bushings just get less & less rubber to make room for the larger bar.
Old 01-03-2008, 06:05 PM
Rockin' NW Arkansas
UPDATE
Well i went down to go talk to a local shop. they measured my sway bar and fount that it was just under 24mm. Is that common or obviously from another car
Matt
Old 01-07-2008, 01:18 PM
Originally Posted by firefighter7128 View Post
UPDATE
Couldn't find the table that broke down the sway bar sizes, but the info in this thread looks like it came from it: bigger swaybars... very impressed!
EDIT: This might be were I saw it originally: http://www.clarks-garage.com/shop-manual/susp-15.htm
HTH.
'77 S with '78 930 power and a few other things.
Old 01-07-2008, 05:56 PM
Dtchy's Avatar
Looks like you have the 23mm bar that was standard on the Turbo. I put one of those on, as well as an matching 18mm rear.
Are you doing anything to the rear?
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 01-07-2008, 07:13 PM
Rockin' NW Arkansas
havent even looked at the rear. tomarrow im doing the struts, breaks, bushings and replacing the wheel bearings. next week i'll do the rer bearings and breaks
Matt
Old 01-07-2008, 10:00 PM
Dtchy's Avatar
Sounds good. Just make sure you balance the front and rear. The 18mm swaybar goes great with your front bar. Not all 944's came with the rear swaybar...Mine didn't.
If the front's too stiff, the car will understeer. You can balance that by adding a rear swaybar.
Old 01-08-2008, 08:24 PM
