winter-hater club member
bad.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Used & Abused
Ok I give, how bad is it?
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
very.
As in jumped timing belt? Did it jump or break, neither is good, breaking is worse. with a jumped belt you can fool yourself into thinking you can replace the belt and you'll be ok....that is until you do and it still turns out you bent the valves. either how, i'd probobly pull the head and inspect the valves and pistons, even if you jumped time, it's possible to damage the valves and pistons. Usually the pistons survive, but better safe than sorry. So that's where i would start. Or you can just be lazy and put a new belt on and then pull the head when/if it doesn't run. best of luck and keep us posted!
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
Trying to work for parts!
What exactly is the question?
86 Metallic Grey 85.5 Metallic graphite - Gone |
jumped what chain?
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
I was told that the turbo can break a belt and not suffer much damage due to the low compression..
am i very off?
Marcone ~87 Turbo ... Vandalized.. now a parts car. ~89 s2 16v ... Getting back on the road soon. ~89 Turbo S ... I GOT ONE.. Hidden away in storage!! ~04 Cayenne S ... |
Sorry to hear that nynor.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
notice that it wasn't me that started the thread. somehow, the original poster was able to start a thread with a title but then didn't have any text. my turbo is fine, as far as i know. i injured my shoulder, so i haven't started it in a few days.
That Guy
The 951 still has an interference motor and the valves will still make contact with the pistons. You may not bend as many valves, but your still bending them.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Dog-faced pony soldier
Compression has nothing to do with it. If the belt breaks, Mr. Valve gets friendly with Mr. Piston and bad things happen.
Expect (in addition to the time & labor to replace the belt) to replace 8 (or 16) valves, possibly one or more of the pistons, possibly having the block re-honed if anything physically breaks off and rattles around in the cylinder (usually not, but possible). Also possible damage to valve seats. It can get fairly ugly fairly quickly.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Used & Abused
951s had sodium filled valves, correct?
If they were, I'd bet they'd be more prone to shearing off rather than just bending like your regular valves would. Bent valves = bad, broken valves = worse.
Yes. The exhaust ones anyway.
Oops sorry Nynor.....
no worries, its an odd post.
