altrernator wires
ok, is there a special way to remove the red wire?? BTW, idk if the photo i added worked.
dolor et pavor Copyright |
Trying to work for parts!
No picture.
The wires should just bolt to the alternator. nothing special about them.
86 Metallic Grey 85.5 Metallic graphite - Gone |
That Guy
Should be a 13mm nut, make sure you disconnect the battery unless its an early 4th of July celebration.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
yeah, i'm replacing the whole starter harness and am a little tricked up on the the red one, because it has a little rubber boot on top. I'm thinking just pull till it comes off, but last time i did that i pulled alittle too hard =0.
