Can't get it started!
My son has 1984 944. Engine stopped while driving in the rain. Checked the fuel pump - seems to be working. Plugs are OK. Changed spark plug wires, distributer cap and rotor, but I only get spark from the front wire on the first plug. The engine turns, so the starter is good. Any ideas as to what to check next???
Old 03-06-2008, 06:06 PM
OnTheRun2's Avatar
Did the coil get wet?
If so and you still have the coil cover on it, it will be shorting out. Try to get it dried out and try again.
(Mae) Red '86 944na- gettting new paint soon.
(Abby) Black '86 944na- new addition to the family.
Old 03-06-2008, 06:53 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Same thing for the distributor & rotor.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 03-06-2008, 07:02 PM
Thanks for the help!!! Distributor and rotor are brand new as of today & everything is dry. Still will not start. I find it strange that I can get spark from one wire / plug but not the others! Next suggestion?
Old 03-06-2008, 07:18 PM
earlr85944's Avatar
swap that plug wire with one that is not firing, if it fires in the swapped position get a new set
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 03-06-2008, 07:32 PM
Did not think of that. Thank you. I will try that tomorrow!
Old 03-06-2008, 07:37 PM
earlr85944's Avatar
ok, also pull the cap off and have someone crank it and see if the rotor spins normally
83 944....bye bye
Old 03-06-2008, 08:01 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
+1 ^^ I agree with Rich...Try to turn the rotor with your fingers. If it turns, you need to reposition it and tighten it up properly. Also look to make sure it's on there all the way and not wobbling. It's unlikely three plug wires are bad, so it's probably more to do with the rotor not touching the dist. cap where it's suppose to because it's wobbling or not turning.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-06-2008, 09:15 PM
