Redline Racer
HondaDustR's Avatar
Where (or how) to have injectors cleaned.
I have just aquired a set of fuel injectors and am wondering what the best way to go about having them cleaned out. Is this something that a reasonable service shop can do a good job on, or will flushing them out with throttle body cleaner work just as well. I want to get it right the first time before I put them in. Thanks in advance.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-13-2008, 08:41 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I sent mine off to get cleaned and mapped. This assures you that you are getting constant amounts of fuel to each cylinder and your engine runs much smoother. I sent them 8 injectors and they picked the appropriate four for me. I usually like doing my own work, but in this case I am glad I did it the other way. I will have to look up the name of the place that did it for me but I think it was witchhunter or something like that. I'll look that up and post back.
This is it:
http://www.witchhunter.com/
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-13-2008, 09:46 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Send them to witch hunter. I've sent them injectors from my 944 & other cars to have them cleaned. Price is very reasonable and the turnaround is usually a day.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 03-14-2008, 09:27 AM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
(Hi Tom )
and dittos,
third vote for Witchhunter, I sent him mine from NJ, had them back at my door in a just over a week! he did a great job. dont forget to give them a quick shot of paint when you get them back.
1995 993 C2
Old 03-16-2008, 10:52 AM
Redline Racer
HondaDustR's Avatar
Yeah, I think I'll send them, plus the ones on the car now, to be cleaned and have the best 4 matched. As for paint, I have some red high temp brake caliper paint I'll use. Then they'll match my ignition wires. I can't wait to see the final difference, since I have fixed just about everything else (TPS, AFM, O2 sensor, vacuum lines, J-Boot clamps, new plugs, ect). It's running better than ever, but is still just a little rough in the idle, and seems to behave as if an injector is leaking or something. Matched clean injectors should finish it up nicely.
It will be a week or two before I'll get a chance to send them out, but I'll post back with the results.
Old 03-16-2008, 05:26 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
A lot of people here and rennlist push witchhunter, they sound like they do go work but I have heard horror stories. I took mine to a local diesel shop. Shop said they were leaking but I don't think they really were. I gave them to lart who in turn sold them for $150 so they must have worked.
Keith
1986 Porsche 951
Old 03-16-2008, 09:58 PM
Redline Racer
HondaDustR's Avatar
Yeah, going by what's on their website, they look like they are a pretty serious performance shop, in which case I don't think I would even consider taking them anywhere else.
Old 03-17-2008, 11:59 AM
I've had good success personally. but I have heard others that said they didn't. I know that when I sent them mine they put on new seals and found one of the injectors had a crack and sold me a good one for $25. the thing I liked was they give you a print out of what your injector was like before & after the cleaning.
If you do send yours to them, would be interested in knowning what your numbers were to compare against mine after they were cleaned. Just to have a refrence.
86 Metallic Grey
Old 03-17-2008, 01:04 PM
flash968's Avatar
west coast - rc engineering
east coast - marren injection
Old 03-17-2008, 03:00 PM
Redline Racer
HondaDustR's Avatar
Yeah, I'll post the numbers. I'm hoping to get it done in the next couple weeks, so stay tuned...
The marren place looks pretty good, but they are a bit more expensive...and a bit out of my price range for 8 injectors.
Old 03-17-2008, 07:49 PM
