FASTLAP
porsche.racer's Avatar
A little help with some transaxle code & #'s
hi again,
I have three transmissions of varying years and cars. I have had many cars through the garage and can no longer pin point what is what.
1. 5S 10045 - this is the only trans I know came from a 85.5
2. MB 29041 - this has the larger diameter 944 shaft - also # 016.301.103R
3. XT 04047 - this has the smaller 924 shaft also # 033.301.103
Any help would be great. I have run multiple searches, tried pelican, and clarks garage without success. I have looked through manuals and porsche books and just cant seem to make sense of the 2nd and 3rd trans's.
Number 1 and number 2 look virtually identical, with very very minor sensor difference (number 1 has additional 85.5 sender)...
1987 911 3.5L
1987 924S
2005 Audi A6 Quattro
2003 Cooper S
Old 04-01-2008, 12:20 PM
The MB is 016G 5 speed from 81 to 82 924turbo, USA.
The XT is 099A 4 speed from 78 to 79 USA and Japan 924.
Found this info in the 924 Technical Specifications booklet (out of print).
Good luck, George Beuselinck
Old 04-01-2008, 12:43 PM
FASTLAP
if the MB is 924T should it not have the smaller diameter shaft? ANd thanks for the help, much appreciated!!
1987 911 3.5L
1987 924S
2003 Cooper S
Old 04-01-2008, 12:49 PM
Dunno, I'm just a 944 guy, so don't know the 924 cars as much as I could.
Old 04-01-2008, 01:05 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Hello,
The 5S Transaxle is for 944 (1985.5 - 1988) USA, Canada, Japan - Without LSD
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 04-01-2008, 04:24 PM
924RACR's Avatar
Nope - 924T has same size shafts (incl torque tube) as the 944. Only the 924NA has the smaller (20mm vs. 25mm) shafts.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 04-02-2008, 05:55 AM
