unindicted co-conspirator
looneybin's Avatar
How do you undo the hatch struts
I just reattached the hatch frame to the glass for the 3rd & hopefully last time, but i wanted to unhook the struts to release the tension on the frame.
how do they come off, i didn't want to resort to brute force, but i'm almost there.
I would like to undo the end that is attached to the glass, so they won't be in the way when the hatch is open.
I know the rear defroster won't work, but i've only needed to use 2 times since i've had the car anyway.
any help is appreciated, i'm about the get out the sawsall
thanks
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 04-02-2008, 04:06 PM
meister member
speedracing944's Avatar
you pry them off. They are held in with spring clips so you need to pull sideways or use something to pry them off. They will pop off and back on again.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-02-2008, 05:45 PM
Step away from the sawzall....
There is a small metal clip that wraps around the ball. Pry it off with a tiny flathead screwdriver, then the ball will pull off easily.
-- Jim
1983 944
Old 04-02-2008, 05:47 PM
