idle fluctuation
I know this is probably simple, but what do you think is causing my idle to fluctuate...its not real bad, just a little rrrrrrr rrrrr rrrrr...enough to drive you crazy
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
hunting idle can indicate a sticking idle stabilizer valve
Any chance you could point me in the right direction with a picture
Could it also be the TPS ?
Don't count out a vacuum leak either. Pretty sure that's why mine wanders, at least.
1985 Porsche 944 - '85/1 N/A, currently for sale. 1971 Datsun 240Z - Street / AutoX car. 2005 MINI Cooper S - Insane daily driver |
update
I sprayed some sea foam into the intake tube running to the ISV and then pulled the elctrical connection of the ISV and shot that with some sea foam lube...idles perfect for now
unindicted co-conspirator
What is this "sea foam spray & sea foam lube" you speak of?
& where do you get it, my idle also hunts when cold & I have not been able to find ANY vacuum leaks.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
