hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
N/A Engine Questions
Had a few question about my car?
1. What would cause the intake and J Boot to have oil in it? Everythign is hooked up.
2. Sea Foam, looking to put some in my oil to clean it, how long can I keep it in before needing to change the oil?
3. Got a small Idle flux, Vacc system is good, along with good fuel and ignition system, suggestions.
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 05-16-2008, 11:13 AM
Greasy Member
many944s's Avatar
Let's start with the Sea Foam... I wouldn't run it for longer than 200-300 miles if you are adding it to a 5w or 10w oil. While it is a great detergent to add to your oil, it will lower the overall viscosity.
Your idle issue and oil in the j-boot may be the same issue. I would look into the seals in the oil-air separator. when these go out, you will start to see oil deposits in the j-boot as you have mentioned, which could also be causing a slight "hunt" to your idle.
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 05-16-2008, 11:56 AM
Arizona_928's Avatar
could that cause oil in the air box as well?
dolor et pavor
Copyright
Old 05-16-2008, 07:02 PM
KY944S's Avatar
Yes. It does slowly migrate to the filter box (its all donwhill). Its an easy fix and most parts places have the o-rings you need (I cant remember the dem. off the top my head).
1987, 944S (168,000 miles)..sold
1986, 944na.
My job is a hobby. My 944's are work.
Old 05-17-2008, 03:42 AM
Professional Bull5hiter
Outback Porsche's Avatar
It depends upon 'how much oil'. More than likely the AOS has failed and needs to be replace. I've just done this myself as I had the same problem. Like me you'll probably find oil dripping from every vacuum hose and burnt oil caked inside your inlet manifold (have fun cleaning that). The oil makes the hoses go hard and brittle. If they are, you'll need to replace these also. if you go genuine with all the parts (if you can find non genuine formed hoses...let everyone know), it'll cost about $500 (the new AOS is around $200). It's not a difficult job to do.
Cheers,
Jeff
Jeff
83 944 Guards Red
23 718 GT Silver
Old 05-17-2008, 04:47 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
or, you could have just overfilled the oil
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 05-17-2008, 06:10 AM
exitwound's Avatar
What would cause oil in the intake/airbox if the AOS seals were just replaced?
-Patrick
Black 1986 944
Old 05-17-2008, 12:38 PM
rudidelange's Avatar
clean oil in the airbox = filling oil to quickly.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 05-17-2008, 12:40 PM
exitwound's Avatar
It's an oil/water mixture, the water probably coming from successive small trips in the car. This is a pretty good amount of oil in the J-boot, and some misty oil in the AFM. How does filling the oil too quickly lead to oil in the airbox?
-Patrick
Black 1986 944
Old 05-17-2008, 01:01 PM
And if it's not clean oil, your AOS is stuffed.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 05-17-2008, 08:24 PM
earlr85944's Avatar
a worn engine or "blowby" can cause this also, do a compression check
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 05-18-2008, 05:40 AM
exitwound's Avatar
compression test shows "green" or what was considered minimal blowby, the rings still good. Any other thoughts that would put oil in the intake?
-Patrick
Black 1986 944
Old 05-18-2008, 01:50 PM
earlr85944's Avatar
valve guides? what kind of mileage do you have, does the vacuum fluctuate?
83 944....bye bye
Old 05-18-2008, 04:51 PM
Wanted to leave an update. Well ended up changing out the intake to my old intake. and the problem went away. Been several months and have had no issues with oil in the system. Not sure if something was wrong with the intake, or if I crossed something hooking it back up. Now if I can jsut get the electical problems fixed!
Old 09-17-2008, 04:48 PM
