tnporsche's Avatar
clutch disk failure
83 NA had a new clutch kit put in b4 I got it. The master cly had a bad enough leak that the clutch did not operate. I replaced the master cly and bleed the system to get the clutch to function. The clutch would not release however and I pulled the clutch out to find the disk was separated, and basically had ate itself, making it thicker than spec causing the "non-release condition"
Before I start putting the clutch back together I just wanted to get opinions as what might have happened to cause this.
"ignore the rust, its been out for a while"
ALSO is the side thats up in the photo, toward the motor or toward the trans?
I forget, and I if it can be put in backwards I'll find a way sometimes
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 06-05-2008, 10:57 AM
Proprietoristicly Refined
John_AZ's Avatar
Here is a pic to Q#2
To add to various opinions about why:
1. Previous owner did too many backward rolling "J" burnouts!
2. Somebody likes to ride the clutch
3. The flywheel was not refinished/polished when disc replaced and chewed it up.
4. Disc was from a wrecking yard or used eBay purchase to save money
Caused a bit of a vibration I bet.
John_AZ
1988 924S + 1987 924S
Old 06-05-2008, 11:38 AM
Back from Beyond
Could be the heater valve blew and yakked coolant all over the bellhousing, contaminating the clutch.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-05-2008, 11:42 AM
Hi, just a guess but maybe the master cylinder adjustment rod where the foot pedal is was adjusted incorrectly and not letting the clutch fully disengauge.
Old 06-05-2008, 04:03 PM
