ace_944's Avatar
Angry Need help finding new exhaust system
I'm looking for a whole new exhaust for my 87 944 N/A. I don't really need anything to fancy just wondering whats the best way to go about getting one.
Old 06-03-2008, 06:42 AM
Feelin' Solexy
Tishabet's Avatar
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_EXHmuf_pg1.htm#item0
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 06-03-2008, 07:15 AM
Custom User Title
mikepellegrini's Avatar
My kid installed a Lindsey Racing 3" catless exhaust on his car (a 951). For the whole thing, (which connected at the down-pipe and included a Magnaflow muffler and tip) he paid $606.
It was relatively easy to install. And it sounds great.
They have a 3" exhaust for the 944 NA that costs somewhat less, depending on what options you get.
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944EXHAUSTMILD
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-03-2008, 07:27 AM
Proprietoristicly Refined
John_AZ's Avatar
The exhaust systems were stainless steel and hold up well. If you do not live in a "rust belt" state you might look into a used exhaust from a local yard to save shipping or look into an internet used supplier like:
http://dcauto.gotdns.com/section/index/3585451/202.
Pelican also has a "classified parts for sale" forum.
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/
Good luck
John_AZ
1988 924S + 1987 924S
Old 06-03-2008, 11:20 AM
thekidd's Avatar
Send a message via AIM to thekidd
Go with The Pelican.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 06-03-2008, 03:53 PM
ace_944's Avatar
If I get the one from LR do i have to get the MSDS headers, or does it come with stock? Also if i get it with a catalytic converter does it come prewelded so i wouldn't have to take it to a shop?
Old 06-03-2008, 06:31 PM
nightheart's Avatar
I'd check out automotion too. You can get a bursch headers and exhaust for a little over 600. downside is the cat is 500. I'm looking myself and will probably get the exhaust there, pick up a cheaper cat somewhere, and take it somewhere to get welded on. I've seen magnaflow cat's on ebay for around 60.
http://www.***************/
This was probably posted from my phone, so please excuse any typos.
Old 06-03-2008, 07:44 PM
My 944 scares adults
lovemy924S's Avatar
Send a message via AIM to lovemy924S
http://forums.pelicanparts.com/forumdisplay.php?f=19
Good luck
John_AZ
I was almost positive the exhaust systems on these cars were NOT stainless, the reason being my exhaust has a very small crack and to check if a local guy could weld it for me i held a magnet up underneath there...it stuck...not stainless steel.
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers
1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?)
Old 06-03-2008, 08:47 PM
Super Moderator
nize's Avatar
uh, magnets stick to stainless steel. from http://www.azom.com/details.asp?ArticleID=1140
Stainless Steel - Magnetic Properties
All stainless steels, with the exception of the austenitic group, are strongly attracted to a magnet.
were you thinking of aluminum?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-04-2008, 01:16 AM
Misunderstood User
Still got the original on my 83. It is stainless and yes some grades of stainless do have a slight magnetic attraction.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 06-04-2008, 07:03 AM
Custom User Title
The LR 3" exhaust my kid got for his 951 just bolted directly onto the downpipe from the stock headders. I would guess their 944NA exhaust would work the same, but just to be sure, you oughta call 'em (or email) and ask.
In comparison to the others, it's relatively inexpensive. And you'll likely see at least a little HP gain (mostly from ditching the cat).
If you do get the cat, I'm assuming it would fit together like the rest of the LR pipes - they use compression fittings. But you might ask them to be sure.
It was relatively easy to install. The only problems we had were that the hanger brackets were a little off. Fortunately, the hangers are adjustable (just loosen them and slide them forward or backwards on the torque tube). It ended up really great.
Below - his stock exhaust and the new LR 3" side by side.
16 Ford Expedition
Old 06-04-2008, 08:29 AM
Redline Racer
HondaDustR's Avatar
They make 2 versions for the NA. One bolts up to a MSDS header and the other is clamped to the stock Y-pipe after cutting the cat off just downstream of the oxygen sensor.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 06-04-2008, 01:20 PM
meister member
speedracing944's Avatar
In the past I have bought a whole exhaust system from the manifold back from a fellow Pelican member for $60. I just posted a WTB add in the parts classified section.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-04-2008, 03:55 PM
3" is serious overkill for an N/A.
When ever I get a chance, I plan to modify the stock cat-back section from my 951, and bolt it to the 944. It's around 2.5", and shouldn't be too much for the '83.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 06-04-2008, 04:05 PM
ace_944's Avatar
Will the MSDS headers fit ok on my car?
Old 06-04-2008, 06:57 PM
Redline Racer
HondaDustR's Avatar
I'd suggest finding a good used stock exhaust system, making a test pipe with a catalytic converter to swap in for passing emissions, mating it with some good headers (MSDS or Bursch), and splicing on a good sounding muffler.
I wouldn't want to go 3", since I've heard these engines don't do so well with a really big exhaust, unless maybe they are specificly set up and tuned to run well at high rpms with a nice open exhaust.
Old 06-04-2008, 07:56 PM
Higher grade stainless is non magnetic.
Jack
Old 06-05-2008, 03:48 PM
