shikzachaser's Avatar
84 is eating O2 sensors
Anybody had their N/A eat O2 sensors every couple months? I have been having a rich mix for a while and have replaced the O2 sensor 3 times now in 5K miles. It is dead again. I have used a stock one and 2 generics from Auto Zone. I have done a few things to the engine but nothing too crazy. I am running MSDS headers and a mini cat. The O2 sensor is in front of the cat in the threaded hole on the header. Any ideas???
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 06-22-2008, 03:54 AM
It probably isn't the O2 sensor. If it's running rich there is another reason. What diagnosis have you done? The car will run with the sensor disconnected anyway.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-22-2008, 09:00 AM
I have a quick disconnect and have measured the voltage from the DME @ right @ 4 volts. All of the O2 sensors have been at least outputting voltage in the 4-5 volt range when installed. I have adjusted the A/F to get close then after a couple hundred miles it is rich again and the output voltage from the O2 sensor is essentially 0. If I stick a new one in it again gives me an output. I am at a loss. I also am not the sharpest tool in the shed and am receptive to ideas.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 06-22-2008, 02:56 PM
FPR or Sticking Fuel injector??
Get Injectors Cleaned could be a start. Vacumm test on FPR to see if it holds perssure.
AFM worn contact?
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 06-23-2008, 06:24 AM
