Arizona_928's Avatar
before replacing the master
before i replace it is their anything i should look out for, and how many hours labor should be?
i'm also planning on replacing the slave, and the hose that runs from the slave to master.
thanks Levi
dolor et pavor
Copyright
Old 07-02-2008, 05:10 PM
DSPTurtle's Avatar
What were your symptoms? Is it leaking or just mushy? Mushy could be a bad brake line...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-02-2008, 06:05 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Which master? Clutch?
Just follow the steps on clarks.
MAKE SURE YOU TAKE THE BATTERY OUT!!!!
It's a pain to do though. Figure 3 hours to do the master. Hour for the slave and an hour to bleed it all if you dont have a pressure bleeder.
Slave is easy though.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 07-02-2008, 06:57 PM
