Palmetto Patriot
Jon Vancil's Avatar
Send a message via Yahoo to Jon Vancil
Deep technical question
Will oem Porsche N 017 586 2, and N 017 589 4 fit in connector oem 171 971 971?
Ok I tried to post this earlier but I got kicked off. The meathead that owned my 944 before me mangled the wiring. The parts above are the metal connectors and the plastic housing. Basically this dude pulled on the wires behind the ignition switch causing them to deinsulate and arc, melting half a dzen wires in the process. I have removed the wiring harness and replaced all the bad wires and tested everything with a multitester. Everything checks out ok. The fuseblock was fried as well. The parts above are to replace a plug that went to the back of the fuseblock that were removed with pliers. The moron also wired a radio shack switch into the console to control the fans. Here is a picture of the fuse block carnage:
1985/1 Porsche 944 1.5% scratched up Crystal Green 98.5% flat putrid red. and *drumroll* 250 lbs of bondo!
Last edited by Jon Vancil; 07-11-2008 at 09:45 PM.. Reason: Connection dropped on earlier post, login issues
Old 07-11-2008, 09:36 PM
TibetanT's Avatar
Jon:
I think I know about this idiot too!! No $hit.
I purchased a 1987 944 about three years ago that would not start, my first BIG mistake, and the moron did the exact same thing you have just mentioned here.
In fact, the gray and black wire was spliced into some type of switch just under the dash board. Of course, these people never leave you a note as to what they did or planned to do. This person even went so far as to cut wires on the E Block so when I finally got the car started (two years ago) it wouldn't turn off when you removed the key from the ignition. Can you believe that?
I really understand and feel your pain here. I just don't understand why someone would take a perfectly wired German car and mess with it like that.
Did you get your situation fixed?
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 07-11-2008, 11:32 PM
Palmetto Patriot
Jon Vancil's Avatar
Oh it gets better! Thats the fried fuse block. What I dint understand is while there has been a great deal of work involved on this, so much could have been avoided by doing something right the first time. Well, I'm glad it worked out though I picked up the car for $500. All I need now is figure if N 017 5862 and N 017 589 4 are the correct pins for 171 971 971 A and I'm in business!
Old 07-11-2008, 11:51 PM
TibetanT's Avatar
Good luck with that. I'm sorry I can't be of more help but my car has a different fuse box all together. Hopefully, another Pelican will chime in that knows the year and layout of your car soon.
Ed Paquette
1983 911SC
1987 944S
Old 07-12-2008, 12:01 AM
Burn the fire.
Brando's Avatar
replacement fuseblocks can be had pretty easily from people parting out early cars...
Depending on how bad the damage is (just the fuseblock and plug or harnesses too?) you may or may not need a replacement wiring harness...
Diagnosing and repairing issues like that are the worst. My mom just had a mis-wired ignition switch (DAPO) take out her main wiring harness on her 82 SC. Estimated $6k from the shop they took it to. Fun stuff!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-12-2008, 12:23 AM
Palmetto Patriot
Jon Vancil's Avatar
I dont need a new harness, I have replaced the bad wires and have a new fuseblock on order. My question is if the parts # N 017 586 2 (pin) and #N 017 589 4 (pin) are correct for #171 971 971 A (housing)?
Old 07-12-2008, 08:37 AM
Jon, where under the dash are the connectors your talking about, I have an 84 and its basically identical to your 85.1 car, If you can let me know where to look ill tell you what it connects to
___________
1984 944NA, Autothority Chip, Sport Package, Cone Intake, Removed crap, Cat-delete
Old 07-12-2008, 09:30 AM
Palmetto Patriot
Jon Vancil's Avatar
Thanks everyone for the interest. I think I may havent made myself clear. I am rebuilding my car's wiring harness. The picture is of the plug I am talking about. What I need to know is what are the part numbers on the pins within that housing? If I know that, then I can order them, and the plug and complete my wiring harness.
Old 07-12-2008, 10:26 AM
Aufenbahn's Avatar
Probably easiest to buy the whole unit in question from someone who is parting out a car, then one at a time remove the wires and replace them with your wires. One at a time so you don't get mixed up.
Andy D.
Currently driving 2005 Audi A4
Currently driving 2006 Ram 1500 sometimes
Old 07-12-2008, 12:24 PM
Burn the fire.
Brando's Avatar
I don't know if the plugs/pins have part numbers themselves. When having to replace parts like that we usually went to a local electrical warehouse. Easier than fighting with parts counter people or getting the wrong part on order.
BUT
I found part numbers in PET that might be useful:
N 017 589 4 - Round Connector, 1.6 X 1
N 017 586 2 - Round Connector, 2.1 X 1
N 017 593 4 - Cylindrical Connector, 1.6 x 1
N 017 592 2 - Cylindrical Connector, 1.6 x 2.5
N 017 599 4 - Cylindrical Connector With Clips, 3.5 X 6
Old 07-12-2008, 02:56 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
I would go to a local electonicics shop and get some pins. No way you are going to get these from a dealer or from Germany.
Or just see if you can get one with some wires from someone parting out a early car.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 07-12-2008, 03:08 PM
