Trying to work for parts!
Send a message via Yahoo to hpservertech
Testing DME
On clarks page for testing the signal to the dme (http://www.clarks-garage.com/shop-manual/fuel-16.htm) Fuel Pump / DME Relay Primary Coil Activation it says to do the following:
Disconnect the plug from the DME Computer. Turn the ignition switch to the "ON" position and check for supply voltage (approximately 12 VDC) from the Fuel Pump / DME Relay to the DME computer electrical connector.
All 944s and 968s - Terminal 18 to Ground and Terminal 35 to Ground
Am I missing something here? But how can I check for voltage when it says to put 18 & 35 to ground?
I am of course having a No Start issue. I'm not able to get spark at the spark plugs. Checking the ignition coil per clarks looks good so far.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 07-18-2008, 07:48 PM
Make sure the connectors for the speed and reference sensors are connected. They are on top near the firewall end of the intake.
Old 07-18-2008, 08:05 PM
Professional Bull5hiter
Outback Porsche's Avatar
It should read;
Between terminal 18 and ground (terminal 5), and between terminal 35 and ground (terminal 5).
Cheers,
Jeff
83 944 Guards Red
23 718 GT Silver
Old 07-20-2008, 06:15 AM
