nightheart's Avatar
need part numbers for early vacuum lines
Does anybody have the part numbers for the early vacuum lines under the manifold?
This was probably posted from my phone, so please excuse any typos.
Old 08-11-2008, 05:02 PM
Professional Bull5hiter
Outback Porsche's Avatar
I Just replaced all the vacuum hoses recently. Here's my list;
Qty 1, 944-107-187-01 Breather Hose from Oil Separator, 924S, 944 (through 1987), 944S
Qty 1, 944-110-361-03 Vacuum Hose, 944(1982-85) W/M573
Qty 1, 944-110-178-00 RUBBER HOSE
Qty 1, 944-110-177-00 RUBBER HOSE
Qty 1, 035133753A Venturi tube
Qty 1, 999-239-011-40 Hose
Qty 1, 944-110-173-00 Hose
Qty 1, 944-110-187-01 Hose
Qty 1, 944-110-182-02 Hose
Qty 1, 944-355-401-00 Hose
Qty 1, 999-181-152-50 Hose, 7,5 X 13,5
Qty 1, N0203621 Hose, 12 X 2,5
Qty 2, 928-573-727-02 Distributing piece
Qty 8, 928-574-717-02 Hose
Qty 1, N0201391 Hose, 4 X 1
Suggest replacing all your hose clamps also.
You can also get kits from Lindsay Racing for the 4mm Vacuum hoses. If you went this way, some of the hoses above are redundant.
I chose to keep it original.
Cheers
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-11-2008, 06:34 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Unless you have a hole burning in your pocket go with the lindsey kit. Much more economical and I dont see how you would ever have a vacuum leak again with it.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 08-11-2008, 06:54 PM
nightheart's Avatar
Ok. 94411017800 (29), 94411018701(21), and 94411017300(13) are the three that the Intake manifold needs to come off to replace right? What about 94411017700(15)?
Basically, I've found a cracked vacuum line under the manifold, and if I have to remove all that crap to replace it, I only want to do it once. Should I replace that expensive sucker, 15 in the picture too, or can that be accessed later without removing the manifold, etc?
I'd like to try to get all the parts I need, before starting this. I know I need intake manifold gaskets, too. anything else?
I also want to make sure I have the right part numbers before ordering. Our host has the three for 14, 21, and 21.75, any place cheaper. I checked 944online and there are about 25 each. This comes at a crappy time, since I'm running a little low on funds. Too many projects at once.
Old 08-11-2008, 11:32 PM
nightheart's Avatar
the only kit I saw at lindsey racing was for the smaller lines, and that is a project for a later time.
Old 08-11-2008, 11:34 PM
Yeah, I replaced the J-hose (15) too. Must have edited it off my list. I actually got my kit from 944Online. If I remember correctly, it also comes with the 4mm fittings and hose (and venturi).
Cheers,
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-12-2008, 01:23 AM
The 944Online kit gives you the basics (probably what you want). The 944Online kit didn't have all I wanted and I ended up getting the rest from PP.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-12-2008, 01:29 AM
nightheart's Avatar
Thanks for the info, you've been a big help. One more question, is this the kit you ordered from 944online?
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1128446166+9441+fueld elivery-9441
Old 08-12-2008, 09:18 PM
That was the kit I ordered.
Cheers
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 12:37 AM
