How do I replace backup/reverse switch?
Hello everyone,
The backup switch on my 1985/1 944 has gone bad and I need to replace it. Has anyone been able to replace the switch without removing the tranny? The switch is located in a very tight spot and I haven't been able to reach it with any of my tools. Thanks, Max H.
Max Hofer 1985 911 Turbo-Look 1985 944 NA Santiago - CHILE Last edited by maxhofer; 08-18-2008 at 09:40 AM.. |
Proprietoristicly Refined
Greetings Max,
No need to remove transaxle. Scrub the dirt and oil away so none falls in hole. You may get better view if you jack up rear and take off trans mount if necessary. Any cheap switch similiar to aftermarket will work to get your backup lights working again. John_AZ 1988 924S + 1987 924S |
Thanks John, will try to do it removing the trans mount to get more working space.
Max H.
Max Hofer 1985 911 Turbo-Look 1985 944 NA Santiago - CHILE |
Just thinking out loud
You don't have to remove the mount. A deep socket is what I used. IIRC, it's a 27mm. 1 1/8 may have been the ticket though.
83 944 91 FJ80 84 Ram Charger (now gone) |
