2.5 & 2.7 differences
What are the differences in the 2.5 and 2.7 engines? What parts will interchange etc.
The search function won't recognize 2.5 or 2.7 Thanks, D
Donnie Currently Porsche-less.....
The 2.7 I believe uses a different water pump. The impeller is larger and will not work on a 2.5.
That Guy
Cylinder head has different water passages which only line up with the 2.7L block and 3.0L blocks. Cylinder head has larger intake valves aswell as oval intake ports.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
