idle setting prcedure
During my battle with getting my car to run I messed with the idle screw on the throttle body and the screw that sets the stop for the throttle. Anyhow it runs rough at idle and hesitates. Is there a procedure to "balance" these two screws?
Mark
'83 Porsche 944 NA
'90 Porsche 944 S2
Old 08-29-2008, 03:48 AM
Proprietoristicly Refined
John_AZ's Avatar
www.Clarks-Garage.com has a procedure to check the TPS on the throttle body.
http://www.clarks-garage.com/shop-manual/fuel-06.htm
This may help to reset the idle and stop positions. The original idle problem may have been more complicated than just the set screws.
Good Luck
John_AZ
1988 924S + 1987 924S
Old 08-29-2008, 06:35 AM
Toofah King Bad
Rasta Monsta's Avatar
Clark's also has the procedure for bypassing the IAC and setting idle speed. As for the set screw, it should just move the throttle plate a squidge from hitting the sides of the TB.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-29-2008, 07:59 AM
bearone2's Avatar
the idle stop should touch, then another 1/4 turn and this one needs to be set right.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-29-2008, 09:10 AM
