Arizona_928's Avatar
HG set include??
the valve stems?
dolor et pavor
Copyright
Old 10-28-2008, 09:30 PM
Greasy Member
many944s's Avatar
Valve seals? Yes.
If it's the Victor Reinz kit, I'm not sure about other manufacturers kits through.
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 10-29-2008, 05:20 AM
Proprietoristicly Refined
John_AZ's Avatar
Originally Posted by many944s View Post
Valve seals? Yes.
many944s,
Question,
Some members use an upgraded valve stem seal like silicon instead of the rubber in Victor Reinz kit. What are your thoughts?
Thanks.
John_AZ
Old 10-29-2008, 05:25 AM
Greasy Member
many944s's Avatar
I would say it is personal preference...
IMO the traditional Viton seal holds up a little better under hard driving conditions.
The biggest problem with valve seals is they harden over time, thus not sealing well against the valve stem. A common "failure mode" if you will, is the rubber under the metal sleeve that holds the seal to the valve guide breaks down, and the seal rides up the valve stem, rendering the seal useless.
-Nick
Old 10-29-2008, 10:23 AM
John_AZ's Avatar
Thanks Nick,
I'm not familiar with "Viton". I found a site that helped me understand better.
http://www.westpaminis.com/vitonseals.html
More info:
Viton valve stem seals are made from hi-temperature Flouroviton with Teflon to prolong valve stem life and have a spring on the wiper to maintain a positive seal.
John_AZ
Old 10-29-2008, 10:50 AM
